Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Duratrax Cliff Climber
Thread: Mamba Max ESC, need help on programming!
Old 04-29-2009, 09:12 AM   #1
Default Mamba Max ESC, need help on programming!
I just need a little help on programming the Mamba Max. What is the best settings for the CC? Im talking about setting in the computer to set drag brake etc...
Parts installed:
Banebots Motors (wired in parallel)
Tq3 controller
2 packs of (5) 2/3a NiMh batteries each pack..12v total (wired in series)
Hitech servo 645mg
Thanks!!!
TheCrow is offline   Reply With Quote
Old 04-29-2009, 10:36 PM   #2
Sounds like a good setup! I would leave the throttle and brake profiles linear, disable voltage cutoff, set motor type to brushed w/reverse, max out the drag brake and make sure you have the latest firmware.
spartacus_nuc is offline   Reply With Quote
Old 04-29-2009, 11:36 PM   #3
thanks for all your help! without you guys this build is just impossible. I will post some pictures when everything is done. Mamba Max is the way to go!
