05-10-2009, 11:08 PM | #1 |
Pebble Pounder Join Date: Jan 2009 Location: san marcos
| First thing to buy after cc.
WEll decided to take the cliff climber with me to the desert, was goin nice and slow did some sand running and first thing when i run it when i get home is crunching nasty sound of alittle bit of sand in the bushings against the dogbones shafts. so if you plan on runnin the freaken thing in any sand GET BEARINGS! p.s. shot a sidwinder snake in the desert. pretty crazy. |
10-04-2009, 10:13 PM | #2 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
FYI the bearing kit from DTXC has i slight problem with the smallist bearing they are 1/2 mm to wide for the axle case it tends to spread the case and bind it. i order the bearings from boca bearings. problem solved.
10-05-2009, 12:59 AM | #3 |
Newbie Join Date: Jul 2009 Location: Sweden
| Bearing to wide
My bearings (from ebay) was also too wide, but there is small rings of plastic on the gears end that can be removed with a knife, then its enough room for the wider bearings |
