Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: A low budget fun build
Old 06-11-2009, 01:41 AM   #1
Default A low budget fun build
Hi,
For a long time I've wanted to build a truck which I can throw at the rocks without breaking to much expensive parts because my Hilux is a bit costly for that sort of thrashing.
So I ordered a Duratrax CC from Towerhobbies. With one of those reduction codes it was quite cheap. All other parts have been layin' around here already.
I didn't change the chassis. I simply stretched the wheelbase to fit the body.
To hold the body, I've mounted two aluminium rails to the original body mounts from the CC and attached new body mounts from a Tamiya TL-01 chassis to hold the new body.
The wheels are weighted with lead weights. The tires are the old ones from my Hilux.
The electrics are very basic. No need to tell you something about them because that would just bore you.
The body is an Axial Betty which I've painted with Tamiya Field Gray. I've applied the paint on the outside of the body, so it will get scratches.
But now some pics:
The flex is enough for what I want to do with it.
I don't like those neon yellow springs. Has anyone got an idea of how to remove that paint from the springs? Could I simply sandblast them?
-Charles
C. Gras is offline   Reply With Quote
Old 06-11-2009, 03:21 AM   #2
I like to #*&^
want more flex? get new shock but yeah i sapose you could sand blast them
2500hdon37s is offline   Reply With Quote
Old 06-11-2009, 05:05 AM   #3
No, the flex is fine. If it had more flex, the tires would rub against the body.
I'll give it a try with the sand blasting. If it doesn't work, I've got a reason for buying new shocks.
Old 06-11-2009, 09:18 AM   #4
spray the shockswith EZ-off oven cleaner, the full fource stuffn not the no fume crap.
Wait a few min and the color can be rinsed rite off.
Sweet looking truck, I'm kinda partial lol but man you gave it the sad eyes LMAO
zueslilbuddy is offline   Reply With Quote
Old 06-11-2009, 03:00 PM   #5
Nice looking rig. That is a great easy way to extend your chassis for new shock mounts. I have had a blast with my CC rock racer and after seeing this I may have to get me a prebuilt and build a scaler. How does it perform with those electronics and one battery?
nascarkeith is online now   Reply With Quote
Old 06-11-2009, 03:08 PM   #6
Don't know. Haven't tried it yet outside.
Maybe I'm able to go for a ride tomorrow. Depending on the weather. Then I will post my experiences.
Old 06-13-2009, 07:35 AM   #7
This morning I went for a spin with the truck. It performed pretty well considering the two motors with only one battery.
I also sandblasted the springs. Worked great. But they flip around like hell in the airstream of the sandblaster. So it's pretty hard to hit them.
Now it looks way better than with the yellow springs.
I know you guys like pics, so here you go:
-Charles
Old 06-13-2009, 11:27 AM   #8
That looks really good. I don't care what people say about the scaleness of MOA axles, yours looks the part.
Jamus is offline   Reply With Quote
Old 06-14-2009, 07:35 AM   #9
Thanks.
I like the looks of it as well. Turned out better than I expected.
Old 06-14-2009, 06:25 PM   #10
What links did you use to stretch it out?
badtoy1986 is offline   Reply With Quote
Old 06-15-2009, 01:28 AM   #11
I used M3 threaded rod and ballheads from Tamiya. So nothing special here.
Old 06-15-2009, 09:27 AM   #12
Looks awsome man, I have 2 CC based scalers and love them for what they are.
To all the MOA Scale haters out there a BIG
blackfoot is offline   Reply With Quote
Old 06-18-2009, 08:41 PM   #13
Now that is simple and cool as hell! Thats what I need to do with the one I have!
RockEd out is online now   Reply With Quote
