Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: Make Custom Links For $8
Old 06-30-2009, 10:53 PM   #1
Default Make Custom Links For $8
I will be posting almost a tutorial on how to make custom links for less than 10 bucks.
The pictures will be on tonight
Thanks also to nascarkeith who told me this idea. great idea nascarkeith
SandThrowinMini is offline   Reply With Quote
Old 06-30-2009, 11:45 PM   #2
Default Custom Links Tutorial
IF YOU SCREW UP ITS NOT MY FAULT
Parts Needed:
I used 4-40 All Thread Rod
i Used 9/32 Aluminum Tubing (beefy)
Stock Links
Parts Breakdown above
Tools Needed:
Vice (makes it easier)
Drill
Saw
Tubing Cutter or Dremel
1st: Remove the stock links and cut links in half
Click the image to open in full size.Click the image to open in full size.
2nd: Drill a hole in the center of the links (MAKE SURE it is in the center and
not to close to the sides)
using drill above
Holes Drilled
3rd:Cut the All Thread Rod to the length you desire. Start threading it one of the half links
4th: Put the threaded link and all thread thru one side of the tubing.
5th: Put the other link thru the other side of tubing and thread it on.
Your links are now made and can be fitted onto the CC
My CC With cutom links
STEERING LINKS TO COME
Old 07-01-2009, 12:57 AM   #3
Thanks for the props on the idea! Very nice "how to" post. Good pictures, simple instructions, and the every important if you screw up it ain't my fault disclaimer.
I have been running my CC with links like this for a month or so. It has taken some pretty nasty tumbles but the links hold strong. The tubing probably actually makes them stronger.
nascarkeith is online now   Reply With Quote
Old 07-01-2009, 03:10 AM   #4
Haha, cool idea, I'm gonna have to try that now. How do you bend aluminum tubing?
Mynameskenny19 is offline   Reply With Quote
Old 07-01-2009, 06:34 AM   #5
Pretty good idea how you did that....nice job
eron is offline   Reply With Quote
Old 07-01-2009, 07:51 AM   #6
Sweet it just so happens my new CC will be in today!
FlexdXJ is offline   Reply With Quote
Old 07-01-2009, 07:53 AM   #7
Very carefully but why would you need to bend it for this mod?
Old 07-02-2009, 05:56 PM   #8
Need/want to bend it for bent lower links. I heard somebody say you have to put the aluminum in the freezer for an hour or so. Does that work to make it bend easier?
Old 07-03-2009, 12:37 AM   #9
Thats a great idea. I bought some short rod ends the traxxas trx1942. It comes with 16 short rod ends and two longer ones. I bought them on ebay for about 4 bucks plus 2 for shipping. Then i went to lowes and bought a 3 foot stick of 6/32 all thread for 2.50. And three one foot sticks of 3/16 x 0.035 wall aluminum tube at 1.50 each for a total of 4.50. All of the part for new super nice links $13.00, I will post picks as soon as i finish them. The traxxas rod ends can pivot much more than the stock links. And you dont have to use the dumb plastic spacers that if you over tighten become junk.
badtoy1986 is offline   Reply With Quote
Old 07-03-2009, 08:52 AM   #10
I just got some 8-32 all thread from Lowes yesterday to build links for my VMG project that I'm gathering parts for. It's killing me having to wait on stuff. lol I can't wait to get started building it.
disturbed n wv is offline   Reply With Quote
Old 07-03-2009, 09:05 PM   #11
that looks good man. nice tutorial man
jakedizzle is offline   Reply With Quote
Old 07-07-2009, 07:34 PM   #12
I don't see what size drill bit you used for this.
Old 07-09-2009, 07:06 PM   #13
Where did you guys find 4-40 all thread ? Just curious?
dirttrackdemon93 is offline   Reply With Quote
Old 07-10-2009, 12:19 PM   #14
LOWE'S p# 137895 3" long $.56 each. Made by HILLMAN.
E4x4Eric is offline   Reply With Quote
