| | #1 |
| Newbie Join Date: Jun 2009 Location: Navasota
| Sponsored Links | |
| | #2 |
| | #3 |
| Pebble Pounder Join Date: Sep 2008 Location: asheville
| Nice, it is a amazing looking chassis. You need to post a video of it crawling. How much did it cost to make?(i may have to try my one I am in green with envy. |
| | #4 |
| I got everything from Lowes for about $20 including the screws. It did a lot better than the stock DTX frame, but I am redoing everything again with ABS for more flex. I kept everything but the back bone. I replaced it with a base trim (1"1/2) from Lowes. ![]() ![]() ![]() ![]() Last edited by E4x4Eric; 07-23-2009 at 10:17 PM. |
| | #5 |
| Cool, thanks for the reply. nuke24 |
| | #6 |
| The wheel base is 12.5" and it crawls 100 times better than stock Note: I added 2 3/32 weld rods iside the base trim to keep the belly from sagging. DTX RTR from Tower H. Replaced all of the bushings with bearings. Replaced the plastic output cups with steel cups and added O ring or fuel line iside the hubbs. Replaced the rear motor leads with bigger wires and used the Dean plugs ( No difference noticed). This is my first crawler and I am very pleased with it after the mod. I have never owned any other crawler to compare it with but it does extremely good. It almost crawl anything you point at it |
| | #7 |
| It is very cool, can you post a video of it crawling? |
| | #8 | |
| Rock Crawler Join Date: Dec 2007 Location: St. Cloud
| | #9 |
| The rods doesn't affect the articulation because they rotate inside the trim. It flexes like crazy so that it looks like a mad worm when I wheel it. I don't know much about RC crawling but this thing is super fun to play with after the mod. |
| | #10 |
| As you drive it and see how it reacts you may notice that one wheel or another will wedge into holes in the rock instead of flouting over the hole. If that happens you may want to think about limiting the articulation some. A general rule of thumb is if you have more than a popcan worth of articulation it will hurt more than help. |
| | #11 |
| | #12 | |
| | #13 | |
Weak stearing can be solved with better servos, I use the Hytec HS645-MG, it is not the best but for the CC that I don't plan to comp it works just fine. The only way to gain axle clearence is to go up to 2.2 wheels and tires (a stronger servo is a must if you do this). Before I locked out my rear end I had the 645 up front and the stock servo in the rear and it worked well and saved a few bucks. When you do that you can get rid of the silly post in the rear linkage too because the servos rotate in opposite directions. | |
| | #14 |
| Ok, well I hope you will post a video, you could always post it on YouTube and post a link on here to your video on YouTube. Nuke24 |
| Thread Tools | |
| Display Modes | |
