Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: Help!!!
Old 07-25-2009, 05:19 PM   #1
spdyracer's Avatar
Default Help!!!
just put in banebot motors and a sidewinder esc. i did the quick program that is in the book. the problem is when i pull the throttle the truck just sits there and rocks back and forth about a half inch back and forth. reverse does the same thing. the steering works just fine. what could be causing this? i am stumped and bummed about this.
spdyracer is offline   Reply With Quote
Old 07-25-2009, 05:27 PM   #2
did you pick it up and see if it will move with no weight on the wheels?
some pics of your set up might help
life_livin is offline   Reply With Quote
Old 07-25-2009, 05:41 PM   #3
spdyracer's Avatar
does the same if you pick it up. i can turn the wheels by hand and they turn just fine, no bind in them. im stumped on this. both motors are turning in the same direction they just don't want to go for than an inch.
Old 07-25-2009, 06:50 PM   #4
benoj's Avatar
are you sure its programed for brushed motors?
benoj is online now   Reply With Quote
Old 07-25-2009, 11:28 PM   #5
check the lipo cut off
xv-townboy is offline   Reply With Quote
