Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: friend needs help reversing rear servo on cliff climber
Old 08-12-2009, 09:22 AM   #1
Default friend needs help reversing rear servo on cliff climber
my friend bought a stock cliff climber and want to reverse the rear servo internally to get rid of the tall post, mine was already done on mine so i dont know how to do it, anyu help would be good.
cdw327 is offline   Reply With Quote
Old 08-12-2009, 05:25 PM   #2
Step by Step Servo Reversingforum/showthread.php?t=53956&highlight=step+servo
this is the link that Jeephead sent to me when i was going to reverse mine. I didnt have a soldering iron at the time so i ended up buying the a external servo reverser at my LHS which is also a goood option
furiousgeorge is offline   Reply With Quote
Old 08-21-2009, 12:00 AM   #3
Diablo169's Avatar
Or you could buy a $7 Reversing Y cable that has a built in trim adjustment from Horizon Hobbies.
Much easier. Plus you can fine tune the trim.
Diablo169 is offline   Reply With Quote
Old 08-21-2009, 12:08 AM   #4
you can buy them, or do it yourself, id try it myself then buy them if it sucks ahah
shadowrejects is offline   Reply With Quote
Old 08-21-2009, 09:49 AM   #5
benoj's Avatar
what i did was just remove the long aluminum piece from the rear which dropped link down. it still steers the same from the look of it, if it is off its so little you cant tell
benoj is offline   Reply With Quote
