Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: My esc wont work?
Old 08-19-2009, 07:42 PM   #1
Default My esc wont work?
I read the instructions and it said, when i hit the gas or braked the LED is suppose to flash when i hit it.
Yet my truck wont move, not will the LED flash.
skeeter1255 is offline   Reply With Quote
Old 08-19-2009, 07:51 PM   #2
what kind of ESC?
badtoy1986 is offline   Reply With Quote
Old 08-19-2009, 08:26 PM   #3
Its the stock one that came with the RTR version
Old 08-20-2009, 08:15 AM   #4
anyone?
Old 08-20-2009, 10:15 AM   #5
Check to make sure the switch is on, if it is, cut the switch off and twist the wires together, your switch might be bad from the factory. I have had a few different ESC's with bad power switches right out of the box. I usually cut them right off now.
blackfoot is offline   Reply With Quote
Old 08-20-2009, 12:49 PM   #6
Yes it turns on, the green light will turn on, but when throttle/brake is applied, nothing happens.
Could really use some help here please. this is new and i cant use it
Old 08-20-2009, 01:07 PM   #7
Do you have steering?
Old 08-20-2009, 01:47 PM   #8
I only have steering if i plug a battery into the reciever. if otherwise no steering.
Old 08-20-2009, 03:35 PM   #9
I would call Duratrax, you have a bum ESC and if I know Duratrax, they will take care of you. They have THE BEST Customer Service right next to Traxxas. I had a rear motor shit out on mine and they sent one right out and my sons is starting to make funky noises now too and I know it only takes a phone call and I will have a replacement for that as well. They don't even bother to have you send the old one in, they just send replacements right out.
Old 08-20-2009, 08:02 PM   #10
ok im calling the number on this page http://www.duratrax.com/techsupport/index.html
yet it seems to connect me to another hobby place.
Is this the correct number, or is there another?
