08-20-2009, 02:12 PM | #1 |
Newbie Join Date: Feb 2005 Location: Pittsburg
| New to crawling.
Well after doing alot of looking around i have decided i want to try out crawling. My first question is, do i have to run dual battery packs with the cc or can i just use one 6 cell gp3300 pack? Second, what, in yalls experiences, are the best things to do to the cc right out of the box to make it a better crawler? All help is appreciated. Jeremy. |
08-20-2009, 03:12 PM | #2 |
RCC Addict Join Date: Aug 2005 Location: Naoma, WV
With only 6-cell, the motors have no torque. They really need the voltage to run well, and even then they aren't that powerful. Some great things to start with are adding weight to the wheels, adding longer lower links to correct the caster, and doing something about the rear steer. Personally I ditched rear steer, but if you keep it then you need to do something about the long extension on the knuckle, too much leverage. I also ran a stronger servo on the front.
08-20-2009, 05:43 PM | #3 |
Newbie Join Date: Apr 2009 Location: Minneapolis
I would for sure ditch the rear steer, i ditched the goofy knuckle for a while but what ends up happening is the wheels will end up getting turned in a direction that you dont want them to. I think you can run one battery but you need to do some re wiring.
08-20-2009, 07:52 PM | #4 |
Oh yeah, you can run one battery, I did, it just doesn't have any power. That is unless you find the magical 7.2V motor with gobs of torque that we've all been looking for. From what I've read the Holmes cobalt is close, but overshoots the goal with too much power. One other thing I forgot to mention, get a 12T pinion for the front axle, just runs better.
