03-26-2010, 06:59 PM | #1 |
Pebble Pounder Join Date: Aug 2008 Location: marlborough, ct
| what does it need?
started looking through, but figured i'd ask. Just bought a cc and am looking for a top 10 sort of mod list. Also anybody run 1.9's ? Dont wanna go crazy, already have way too much$ in rc. So far it seems metal gears are #1. someone with the climber knowledge can whip a response up quicker than me shovel through the forum. thanks- ben
03-26-2010, 07:03 PM | #2 |
Rock Stacker Join Date: Jan 2010 Location: Lakewood, CO
i love a top 10 too. it would be great to hear from the guru's of the Cliff Climber.
03-26-2010, 07:05 PM | #3 |
also where to get cc parts
03-26-2010, 07:46 PM | #4 |
I joined the Band! Join Date: Mar 2010 Location: nashville,TN
i have a custom cliffy i think i totaled it today but not alot of bolt on parts. i have made alot of mine. one thing you must get longer chassis the chassis restricts it so much oh and longer shocks like 180mm or something i know they are big but they work. i wouldnt get bigger size tires but not smaller if any thing bigger but more grip on stock tires i melt baloons around the tires helps alot |
03-27-2010, 09:36 AM | #5 |
Quarry Creeper Join Date: Nov 2008 Location: Milliken,CO
Stretching the wheelbase is one of the best upgrades you can do. Either make longer links or a longer chassis. A stronger steering servo makes a big difference with metal steering links. I lke the metal wheel hexes they fit the wheels alot better.
03-27-2010, 10:50 AM | #6 |
has anyone tried the upgraded motors if so how are they
03-27-2010, 12:18 PM | #7 |
Rock Crawler Join Date: Sep 2005 Location: Duncan, BC, Canada
1. Metal Gears, 2. Ball Bearings 3. shave the axle housings 4. stretch it to 12" (I used longer links and some custom shock mounts - the stock chassis is fine just needs some tweaking), 5. Better tires 6. better shocks (I still use stockers but I have replacements already - the lower caps keep popping off, bad design) 7. 9T pinions (.6 mod) 8. Better electronics (only if you got RTR - otherwise just a better servo) 9. Banebots 395's, or Tamiya RS380SH's or GWS EP400's 10. now you'll need steel out drives |
03-27-2010, 12:36 PM | #8 |
RCC Addict Join Date: Aug 2005 Location: Naoma, WV
I would put having offset pinions, 12-front and 11-rear in my case, towards the top of the list. I never tried any of the 9 or 10 tooth pinions but the offset pinions made a huge difference in clodstall to me.
03-28-2010, 07:08 AM | #9 |
i appreciate the responses.
03-28-2010, 11:08 AM | #10 |
Quarry Creeper Join Date: Oct 2009 Location: Florida
Stock, at least mine, performed better on the rocks drooped
03-28-2010, 07:19 PM | #11 | |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
this post should be sticky...... | |
03-29-2010, 03:03 PM | #12 |
yea just drooped mine today but letting all batteries charge up then goin and trying it for me the drooped thing didnt really work hindered me on some of the tuffer lines Last edited by crawlinnTN; 04-01-2010 at 10:03 PM. |
04-02-2010, 03:34 PM | #13 |
Newbie Join Date: Jul 2009 Location: Sweden
| My modification list
Necessary mods: 1. Clock the axles 2. Remove all flex so the rear steering works (or remove it) 3. Do something to stop the drive shafts to slip in the axles (to short) Optional: 4. Stretch the wheelbase 5. Change bushings to bearings 6. Get a better gear ratio And this I my own opinion, most people here just talk about other motors, why? If you really want to crawl - do something to reduce speed instead! CC it’s too fast for serious crawling even with stock motors - why make it worse? Think more torque, but without any more speed, because the other big problem is that rear motor stall. But with a better total gear ratio both problems are gone. I added an extra gearbox on each motor. These gearboxes with 1.7:1 ratio gives the CC the speed and crawler capability that it needs, and clod stall is completely gone! Now the total ratio is up from stock 28:1 to 47:1 (as AX-10 Scorpion has) To compare with the 10T discussions theese gearboxes would be equivalent to between a 6T and 7T! The rear axle has torque enough to spin until it is tipping over! Full throttle is no longer necessary; the power is available from the lowest possible speed. And don’t waste money on metal gears until you manage to break one of your plastic gears – all mine still stands against the almost doubled torque they get! Read more in my built thread. |
04-25-2010, 08:28 AM | #14 | |
Quarry Creeper Join Date: Sep 2009 Location: west sacramento
^exactly. also when you change your tires, *rc4wd rock rippers* wheels. the offset will keep the tires from rubbing the links. | |
04-25-2010, 09:34 PM | #15 |
Newbie Join Date: Apr 2010 Location: Denver
Nitrous and an extinguisher!
04-26-2010, 05:49 PM | #16 |
dont forget a weiand blower,12in slicks, and a roll cage |
05-19-2010, 06:53 PM | #17 |
Quarry Creeper Join Date: Jul 2008 Location: Garden State
When stretching the wheelbase to 12 how long do you need to make the links? I just bought a used CC and I want to stretch it but I never did this type of mod before.
05-19-2010, 09:00 PM | #18 |
dude i picked up some axail scx10 stock links for like 50 cents for 4 and work awesome |
05-19-2010, 09:10 PM | #19 |
How long did they make your WB?
05-20-2010, 04:37 PM | #20 |
not sure tore apart for new chassis, but i think maybe 11 or 11.5 |
