Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Duratrax Cliff Climber
Thread: duratrax cliff climber gallery
Old 08-23-2008, 02:03 PM   #1
Default duratrax cliff climber gallery
''This thread is for COMPLETED pictures of your Duratrax Cliff Climber crawler. No in progress build pictures, just ready to go finished crawlers. Also post a list of specs so people know what you are running. Also feel free to link to your personal build thread if you have one.
corvette crawle is offline   Reply With Quote
Old 09-03-2008, 04:51 PM   #2
Lucky's Ride
mamba 25 powered
3 cell apogee 1000mah limn pack
2.2 Flat Irons
Bermbuster is offline   Reply With Quote
Old 12-01-2008, 03:42 PM   #3
Default Here is Mine
WB-317.5MM, 12.5"
Track-234.95MM, 9.25"
Holmes Colbalt Motors
Berg 12 tooth pinions, Metal gears, main is on BO
Stock toothpicks until CVDs get here
Mamba Max
3c 11.1 Lipo
Hitec 5955TG for steering
TowerPro MG945 for Rear Dig
Integy MSR10 set up Droop
Proline Eight Shooter Bead Locks w/M3 Flat Irons and memory Foam
Body- Sand Scorcher Lexan replica
vltchkr is offline   Reply With Quote
Old 12-02-2008, 09:36 PM   #4
Here's mine
washracer_11 is offline   Reply With Quote
Old 01-01-2009, 02:32 PM   #5
Default Thunder's ride
Gotta represent DDM lol!
rear locked out
thunderwagn is offline   Reply With Quote
Old 01-26-2009, 12:52 AM   #6
that black bug is so sick!
zipher is offline   Reply With Quote
Old 01-26-2009, 09:14 PM   #7
It is never finished!
HardcoreTJ is offline   Reply With Quote
Old 01-28-2009, 05:06 PM   #8
This is what happens, when you have a nice Clod body and stock chassis and a top heavy, low performing Cliff Climber mixed with alot of ambition and some time to spare. It took all of 2 hours to complete. Its not completely done, I plan to tummy tuck it soon. I would have gotten alot more pics, but my camera is on its last leg and I had to fight with it to even get these 2 pics.
Stock 5500 380 motors
Traxxas EVX2 ESC
Dual Intellect 1600 2/3 cells
HiTec 625MG servo.
blackfoot is offline   Reply With Quote
Old 02-12-2009, 10:06 AM   #9
Default Extended chassis CC with extra stuff and 2.2 wheels etc
Lowes Special 1/8 Aluminum stretch
Photobucket
All you need
Got twist
What steering post
Holmes Hobbies Pullers 400
richmondcrawler is offline   Reply With Quote
Old 02-24-2009, 08:47 PM   #10
Default Updated with Holmes Hobbies, bent links and all metal gears
also rooster crawler ESC and LED lighting
Old 03-02-2009, 10:24 PM   #11
Default DTX hooters style!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
updated pics 4-11-09
medina619 is offline   Reply With Quote
Old 03-06-2009, 06:49 PM   #12
Heres mine, only "mods" is deans plugs, only about a hour drive time on it, nice rig for $120.
InFlames is offline   Reply With Quote
Old 03-07-2009, 10:27 AM   #13
Default Keeley's Cliff Climber
This is my girl friend's Cliff Climber. She was really happy to get her own rock climber. It is almost stock, the only thing I did was to re-solder and reverse rear servo to get rid of that goofy spacer. Hope you like it.
Jeephead is offline   Reply With Quote
Old 03-11-2009, 09:40 PM   #14
Default My extended CC
List of upgrades:
Pro-line Hammers M3 w/memory foam
Axial beadlocks with custom outer rock rings, 2 -1/8 in. vent holes in each
3 3/4 oz.weight in front wheels and 2 oz in rear wheels
Aluminum knuckles front and rear
Cv axles front and rear
Aluminum wheel hexes
Duratrax Big Bore shocks with medium springs
Extra spacers on upper shock mounts
Aluminum steering links
Locked rear steer
All metal gears front and rear
Bearing kit
Aluminum links with bent lower links
Traxxes rod ends
Custom Stretched Frame
2 - DTX 1600mah 6 cell batteries
Heat sinks on front and rear
Aluminum Body mounts
Spektrum Dx3.0 Radio w/Sr3000 rx
Pro-line 72 Chevy truck body trimmed
Mamba Max on order
waiting for good motor upgrade
Clocked front axle -it is now level
axial front steering links cut down
Axial offset rod ends on steering link clears axle housing for better steering, turns till knuckle hits axle housing.
Spektrum z590 servo
Metal servo arm
Moved links to outside of axle mounts
Mamba Max
Trimmed body for better clearance
doubletrouble is offline   Reply With Quote
Old 03-24-2009, 02:39 PM   #15
Mostly stock for now with novak rooster crawler, JR st126mg servo, stock motors, 7 cells. Not much power, I'm looking at other options.
More mods thread My project CC on a budget....for now
brokenb4 is offline   Reply With Quote
Old 04-21-2009, 12:33 PM   #16
Default Rockbuggy
[IMG]Photobucket[/IMG]
sweli is offline   Reply With Quote
Old 04-21-2009, 12:54 PM   #17
~THE SCALE SHOP~
TSS CCX chassis
Mayhem wheels
STANG KILLA SS is offline   Reply With Quote
Old 05-01-2009, 10:06 PM   #18
Default my cc
no mods yet except 2.2 axial rockstar beadlocks and pro-line 2.2 chisel tires with memory foam, 100mm new shocks have been ordered should be here next week along with new frame. basic electronics for now that come on the rtr. future plans would be tube cage and bash it... Image Hosting> Image Image Hosting>Hosting> Image Hosting> Image Hosting>
dragit is offline   Reply With Quote
Old 05-02-2009, 07:51 AM   #19
Those tires look cool on there! How are you mounting the 100mm shocks with added towers? I want to upgrade mine but am NOT paying $70+ for bigbore Duratrax shocks +brackets.... I be cheap that way.. HA!
Old 05-02-2009, 09:16 AM   #20
Here's mine
Mostly Stock
H.T. 625 servo
MRC rims and tires
On_The_Rocks is offline   Reply With Quote
