Thread: Probs with ESC
Old 05-27-2005, 02:52 PM   #1
Default Probs with ESC
I am having a problem with my TXT. The last time I ran it at first it would just lose the connection, like a loose plug or something. Then towards the end of the run it would not run at all. Would it be a bad connection or am I going to have to buy another ESC? I am running a SR with Hitech Transmitter/Receiver and stock motors
jeep_boy02 is offline   Reply With Quote
Old 05-27-2005, 03:07 PM   #2
how many runs on the motors? i guess wiring or the esc has de-programmed itself and needs to be reprogrammed.
chafey is offline   Reply With Quote
Old 05-27-2005, 03:09 PM   #3
if you are using the stock tamiya connectors that could also be your problem
Old 05-27-2005, 03:09 PM   #4
if you still have the stock tam plugs on then that is the problem.replace with good deans plugs
SPEED_RACER is offline   Reply With Quote
Old 05-27-2005, 03:20 PM   #5
I didnt think bout the connectors. You are talking bout the ones for the motor right? My light on the ESC is on like it has power to it, but the truck does not respond.
Old 05-27-2005, 03:29 PM   #6
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
the connectors on your motor, and the ones on your batter/esc.
replace them all with deans, or hardwire.
JohnRobHolmes is offline   Reply With Quote
Old 06-02-2005, 05:59 AM   #7
sounds like it could be bad brushes also.
envious8420 is offline   Reply With Quote
Old 06-02-2005, 11:58 AM   #8
its definatly the connector. i had the same problem. is the whole truck shuting down, like the reciever and all?
ILoveRCRockCrawlin is offline   Reply With Quote
Old 06-03-2005, 12:39 PM   #9
It shuts down and wont do a thing, but like I said earlier the light on the ESC is on like it has power to the ESC, but not to the motors or servo.
