06-02-2005, 04:32 PM | #1 |
Rock Stacker Join Date: Apr 2005 Location: SoCal
| LRP AI Bullet
Any one use the AI Bullet?? How does it handle 2 high torque servos and motor?? ANY one using anything else besides a SR??? What other ESC are comparable to the SR in performance??? .... Tekin Rebel 2... Last edited by SantozRey; 06-02-2005 at 05:18 PM. |
06-02-2005, 04:41 PM | #2 | |
RCC Addict Join Date: Dec 2004 Location: Central NY
06-02-2005, 05:17 PM | #3 |
well I ain't a magician :?
06-02-2005, 05:30 PM | #4 |
Pebble Pounder Join Date: Apr 2005 Location: Torrance, CA
The Tekin Rebel 2 is ideal for crawling and is a bit cheaper than the SR.
06-04-2005, 08:11 PM | #5 |
Well,I've not run it but three 45 to 50 minute runs but I'm now running a Novak XRS and so far I'm very pleased with it. One thing I like is that it's a small unit so it's easy to fit when space is limited. After I get some more runs on it I'll be able to tell more but so far I like it alot. Only time will tell I guess.
06-04-2005, 11:38 PM | #6 | |
06-05-2005, 12:00 AM | #7 | |
Well,I didn't know that,thanks for the info. Not knowing much about how all that stuff works and the way I'm understanding your post. Thats probly where my glitchs were coming from then?,right? Running a RX pack it seems to work fine with 1 servo(hitech 645). Would this put a strian on the ESC? I'd like to go to 2 servos if I can get away with it. What do you think? | |
06-05-2005, 12:21 AM | #8 | |
06-05-2005, 12:24 AM | #9 | |
soo do you currently run a Rebel 2?? After looking at both the SR and Rebel 2.... they look almost about the same. I'll probably get 2- HS-645 (unless I get my hands on some cheap 945's) and an integy 55t... with the Rebel 2. Do you think that the Rebel 2 will be up to handling a 17t motor??.... sometimes I like to go fast... .... with both servos? :? Last edited by SantozRey; 06-05-2005 at 12:30 AM. | |
06-05-2005, 01:46 AM | #10 | |
Really for crawling, the only limit we even get close to is the BEC and the Rebel 2 BEC is rated almost twice as high as the SR. All the other specs of either controller are waay above the requirements of crawling. All that aside, what really makes the Rebel 2 attractive is the price of $79 versus the SR at $129. | |
06-05-2005, 06:48 PM | #11 |
Quarry Creeper Join Date: Nov 2004 Location: MANVILLE
the rebal2 has just about the same specs as the orig rebal except for the bec.on my orig rebal the lowest duel motors is 17t on 6 cells in a clod.it will thermall with 8 cells.but w/ 17t it handles it ok.this is for bashing not crawling.
