06-04-2005, 05:42 PM | #1 |
RCC Addict Join Date: Apr 2005 Location: Seattle
| Who runs an M8 and can help me out?
I got a used M8. I already have the MX-3, so a lot of the controls on the M8 make sense, but there is quite a bit that does not. For example... What does exponential actually do? How does the radio control speed, and of what? RSP. I have no idea what that is. Response? TRM(SUB), TRM(RATE) and TRM(RST). I am assumming Trim, and the first one is likely sub-trim, but what are the last two? LAP-T, is that a lap timer? INT-T, I have no clue S-POS, no idea CMD-S, no idea CONT, no idea The screen says ALB (whatever that is) is on. What is it? |
06-05-2005, 01:07 AM | #2 |
Quarry Creeper Join Date: Feb 2005 Location: Lake Tapps, Washington
EXP-Lets you cruve the TH or ST, like if your car respons to quickly to steering you can go - on the EXP, and the same for TH. SPEED- You can slow down the servo speed of a fast servo but you can't speed up a slow one. RSP. Response?- Yes, its a lot like EXP TRM(RATE) this adjusts the degree of trim available TRM(RST). (RESET) This sets all your trims positions to memory LAP-T, is that a lap timer?- Yes INT-T(interval time) its a timer, can be used to time pit stops S-POS- used for gas cars, it lets you bump the TH. up for starting a gas car CMD-S- Changes the tones on the radio CONT- LCD Contrast ALB- anti lock brakes I B.. Last edited by I B RACIN; 06-05-2005 at 01:10 AM. |
06-05-2005, 07:47 PM | #3 |
Anti-lock, huh? Sounds like that would be bad for the bashing I do. I want ro be able to come slidig in sideways, etc (XXX-S touring car). How do I turn it off? I can't find anything about it other than that it says on the screen that it is on. |
06-06-2005, 12:07 AM | #4 |
move the cursor to the far right just past the (st speed th) its a blank aera, Then use the +/- keys to turn on or off. I B.. |
06-06-2005, 12:13 AM | #5 |
Awesome, thanks.
06-06-2005, 12:14 AM | #6 |
If you race touring cars, and your in Redmond. You must know Sean (Tinkerbell) maybell, He used to work at the hobby shop in Redmond and he might still I have'nt seen him in about a year and a half. I B.. |
06-10-2005, 07:19 PM | #7 |
No, I don't race anything at all. I have the XXX-s, but I'd unload it in a second if someone wanted it. I know all the guys that work at Hobbytown in Redmond, the only one I know that races on-road is Tom.
