02-07-2008, 07:55 PM | #1 |
Rock Stacker Join Date: Nov 2007 Location: The Granite state
| rooster crawler problem
Well i screwed up , i was straightening my wires out to make them look beter and wire tieing them and i accidently snipped the red wire going to the switch. The battery was not plugged in . Ive been playing with electrics quite a while and had a perfect track record , ive never fried or ruined anything, i'm always real careful. I put the wire back together and light comes on but it will not program so no power to the wheels and no steering also . Any ideas?? Should i just ship it back to Novak?? I also tried a different reciever and checked all my other wires. Thanks Herb |
02-07-2008, 08:01 PM | #2 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
Is it your on/off switch or your receiver harness. |
02-07-2008, 08:09 PM | #3 |
The on off switch.
02-07-2008, 08:12 PM | #4 |
Where did you cut it at. Like in the middle or more towards the end. Can you just re-solder the switch |
02-07-2008, 08:17 PM | #5 |
i cut it about a 1" or so from where it is soldered on to the esc and i did resolder it and no workie . when i turn it on the red light comes on , it will not program and no motor power and no steering. Its completly dead other than the red light on the esc.
02-07-2008, 08:20 PM | #6 |
Did you at any time disconnect the receiver harness when it happen or when you went to re-solder it
02-07-2008, 08:22 PM | #7 |
i've disconnected everything when i fixed and the battery wasnt even plugged in when i snipped it to begin with. i even tried another reciever.
02-07-2008, 08:25 PM | #8 |
Herb, check your receiver harness and make sure that on the esc the white wire is to the outside of the esc.
02-07-2008, 08:30 PM | #9 |
i did that to , it has the configuration right on the side of the speed control. Ive been looking this thing over for a good 30 minutes and i see nothing wrong .My guess is its done. What really gets me is the battery was unplugged and i only snipped one wire , it wasn't like i snipped a bunch at once .
02-07-2008, 08:33 PM | #10 |
So the white wire is to the outside of the esc. |
02-07-2008, 08:35 PM | #11 |
yup sure is
02-07-2008, 08:39 PM | #12 |
Herb it don't make no sense, just cutting the wire for your on/off switch. There is no signal wire. |
02-07-2008, 08:44 PM | #13 |
I know thats why i posted this , it doesn't make sense , i'm tempted to cut the black wire to and wire it to the red one and eliminate the switch to see if that fixes it , but if i'm gonna send it back i probably dont want to be hacking it up .
02-07-2008, 08:58 PM | #14 |
Well looks like your best bet is to send it back to novak. Dude I'm sorry to here that It really sucks. Darren :-(
02-07-2008, 09:02 PM | #15 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
Is it pluged into the 2nd hole and not the 1st with the servo in the batt. slot?
02-07-2008, 10:12 PM | #16 |
ok now i feel stupid , i took the esc wire that goes to the reciever completly off to inspect it good, Novak has them things twisted up pretty good , come to find out the black wire had broke off near the plug. I could't see that with the way it was twisted from the factory. i must have broke it when i was tucking the wires trying to make them neat. I had a spare harness ,plugged it in and bingo, took a program and works fine . Thanks for the suggestions. I,m glad it was something simple i overlooked.
02-07-2008, 10:27 PM | #17 |
Herb, I had a feeling that it was something to do with the receiver harness. Mine did the same thing when I had it backwards on the esc. |
02-08-2008, 01:50 PM | #18 |
It was very hard to see the way the wire is twisted , i was ready to go out and buy a mamba max. lol
