02-11-2008, 06:07 PM | #1 |
| Am I doing the math right??
Just received my new packs from CBP's and I want to make sure I am doing my math correctly. The packs are 9 cell 2/3A 1500 Elite's and the charger is the Piranha digi peak. I'm setting up the charger for the first 10 hour charge on these packs. If I take the capacity and divide by 10 (1500/10) I get 150mah. Then if I take the 150mah and divide that by 1000 to get the amps...I come up with .15A. So on the charger, I have an option of changing the current, and this should be set to the .2A correct? (can't get .15...options are either .1 or .2) How high can I set the peak mV/cell on this first charge? Is 5mV a good start or should I go with like 3mV for the initial charge and then 5mV after that? Once I have this initial charge out of the way, the new setting should go up to 1.5A current.....correct? |
02-11-2008, 06:47 PM | #2 |
.2A should be fine for the first charge and yes 1.5A is good after that. I have tried to charge mine faster and even at 1.6A my packs get hot. I don't know about the peak mV/cell, I never mess with that on my Triton2. |
02-11-2008, 07:31 PM | #3 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
Most of my 2/3A packs reach a full charge on a 6 to 7mv setting. I would start around 4 or 5 and check the temps at the end of charge. If the pack is not getting warm enough at the end of the charge cycle, I would bump the mv up a notch. I will charge them at 1.5 amps if I need them in a hurry but mostly at .7 or .8 amps. |
02-11-2008, 08:57 PM | #4 |
RCC Addict Join Date: Jan 2004 Location: Gunbarrel
Your using this charger right? http://www3.towerhobbies.com/cgi-bin...&I=LXCLD5&P=SM If your are it is only rated for 1-8 cells. If not then you should be fine with what you are planning on doing. |
