02-13-2008, 12:04 PM | #1 |
Quarry Creeper Join Date: Jan 2008 Location: Switzerland / Geneva
| [RESOLVED] HELP! Mamba max and integy 10 red led !
Hello I have a big problem, My Mamba Max who had a 1.09 firmware fonctionait perfectly, I put in 1.17 and now the engine is no longer working (integy V10) and I have a red LED that flashes. Help me I do not know how to operate my RC! HELP! Thanks in advance for your response and your help Stephane Last edited by SwissSteph; 02-13-2008 at 04:15 PM. |
02-13-2008, 12:47 PM | #2 |
Quarry Creeper Join Date: Dec 2007 Location: OP KS
Make sure your connections are plugged in correctly. Usually the neg goes to the outside of the rx. If they are plugged in backwards, it will give you a red light. I am running a Futaba radio and need to run it in R mode and cross the red-black, black to red to get it to work properly.
02-13-2008, 12:58 PM | #3 |
My problem is, everything was working perfectly before changing my firmware mamba Any solution ? Help |
02-13-2008, 01:50 PM | #4 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
Have you reset your end points? I would try that first. I had to reset mine when I went to the new version.
02-13-2008, 01:59 PM | #5 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
I had to go back to the 1.09 program.If your running a external bec you might have to up the voltage.Good luck
02-13-2008, 02:34 PM | #6 |
02-13-2008, 03:15 PM | #8 |
Rock Crawler Join Date: Apr 2006 Location: Eau Claire
when I updated mine I went in and reprogram'd.......works the same as it was prior..
02-13-2008, 04:08 PM | #9 | |
Thanks Stephane | |
