02-22-2008, 10:37 AM | #1 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| Servo amps & voltages ... specific questions
I know how many volts I'm running to my servos because I have my CC BEC set to 6.6v ... but what about amps? About 2? Also, can someone tell me about how many volts & amps get pushed to a typical servo motor (litle on inside the servo itself)? Ball park figures will work for this... Last edited by Locked Up; 02-22-2008 at 11:05 AM. |
02-22-2008, 01:31 PM | #2 |
Quarry Creeper Join Date: Jul 2005 Location: Utah
It all depends on how many volts your battery pack is. The higher the voltage the lower the output amps on the bec. You should be getting more than 3 amps to your sevos even if your current setup uses a 3-cell li-po. Usually you don't want to go much over 6 volts on the servos, and 2 servos should use (in the neighborhood of) about 3 amps. Someone correct me if I wrong please.
02-22-2008, 01:46 PM | #3 | |
My batteries are mostly 8.4v, but I do have one 9.6v. Any idea what the little motors inside draw? | |
02-22-2008, 01:48 PM | #4 | |
A Hitec 5645 digital servo can draw 4 amps at max load. A weaker digital or an analog servo usually draws a little less. Most servo manufacturers don't post info on amp draw. | |
02-22-2008, 01:51 PM | #5 | |
Hitec servos can handle 7.2V but I think it shortens the life. Don't keep the steering turned at full lock for a long time if they are at 7.2V, that'll burn em up. | |
02-22-2008, 02:00 PM | #6 |
yeah I realized I said pushed after I typed it. Nobody is perfect I'm not running Hitec servos, I'm using Tower Pro 945/6s mostly. So about 4a (or less) is a max load for a mid sized servo like those ... excellent. Now if I can just figure out the draw on the little motors I'll be set. I've been looking around for reaplcement motors to see if I could find specs but I haven't found any yet. |
