03-04-2008, 01:38 PM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: Carlisle
| mamba25 and crawlmaster 3014 problem?
what settings are you guys running if you have this set up? the problem im having with mine is that when I turn the wheel right or left then give at throttle in forwards or reverse it dosent go. but if im giving it throttle then turn theirs no problem. im also running a castles bec. any help would be great.
03-04-2008, 01:42 PM | #2 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Which version of firmware are you running? What are your settings on the mamba 25 at? |
03-04-2008, 01:59 PM | #3 |
the version is 1.17 and the settings are all at the recommended settings
03-04-2008, 02:14 PM | #4 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
Kinda hard to help you when you won't tell us what the settings are. |
03-04-2008, 02:20 PM | #5 |
brake/reverse type- proportional w/reverse lockout brake- 50% reverse- 50% punch control- 0% drag brake- 0% start power- low motor timing- normal (10) motor type- brushless arming time- 1.5 seconds cutoff voltage- no cutoff throttle dead band- average (0.1000 ms) |
03-04-2008, 02:25 PM | #6 | |
I am surprised to see such low brake & reverse and no drag brake in crawler. I have those all set to 100% on my Mamba 25. | |
03-04-2008, 02:33 PM | #7 |
03-04-2008, 02:34 PM | #8 |
03-04-2008, 02:35 PM | #9 |
| How much voltage are you running? That is a huge question I forgot to ask. Edit: What are the settings on the CC BEC? What brand of servos? Digital or Analog? Last edited by Nova's Ark; 03-04-2008 at 02:37 PM. Reason: Added more questions |
03-04-2008, 02:36 PM | #10 |
03-04-2008, 02:38 PM | #11 |
Radio?
03-04-2008, 02:40 PM | #12 |
tq3 radio and reciver, 6.0 from the bec, a jr9000 digital high torque
03-04-2008, 02:44 PM | #13 |
Well, something does not sound right. The 9.6volts should be plenty from the 8 cell and the BEC set at 6 volts with 10amps should push any servo(s). What is the weight of the rig and what size tire? I ran my Mamba 25 in a 2.2 tuber, with a blue label Holmes revolver (brushless), no BEC and 7.4 2S lipo and never had any issues. |
03-04-2008, 02:45 PM | #14 |
im running an axial and it is very light very close to being to light
03-04-2008, 05:28 PM | #15 |
Quarry Creeper Join Date: Nov 2005 Location: The Great White North
Have you disconnected the Red Wire on the Servo harness of the mamba 25 ESC? If you don't do this the BEC built into the mamba 25 is still active and can interfere with your external BEC. |
03-04-2008, 05:58 PM | #16 |
| when i do that nothing works at all. I was down at scale speed today and we tried that
03-04-2008, 06:35 PM | #17 |
| If that is the case, that would explain your problem. The mamba 25 BEC is very low. That JR servo would use all of the BEC and stall the motor when turning (IMO, could be wrong). If your CC BEC is not working, that is your problem.
03-04-2008, 06:57 PM | #18 |
RCC Addict Join Date: Jan 2006 Location: The Amish Ghetto
hey i was just thinking about this... check your power wires going into the bec.... if you pinched them or there is a bad solder joint on them then that is why it wouldnt have power when we took out the red wire on the esc. |
03-04-2008, 07:00 PM | #19 |
03-04-2008, 07:04 PM | #20 |
true.... what about the servo plug. is everything kosher on that end? try getting it to steer without the esc plugged in at all. once you have that solved you can take the red wire off of the esc plug and it should work. also just make sure that the servo plugs are in the correct way. |
