03-09-2008, 06:28 PM | #1 |
Rock Crawler Join Date: Mar 2005 Location: Dude on my dirt bike in SoCal!!!
| how many rpms (55t 6cell nimh)
OK im thinking of going brushless and was wondering about how many rpms a 55t lathe motor does at 7.2ish volts. I had an integy 55t for 3 yrs and the comm finally wore out haha. Thanks Ben |
03-09-2008, 09:44 PM | #2 |
Somewhere around 850 to 1000rpm/volt unloaded. Depends on many factors of the motor and timing.
03-09-2008, 10:52 PM | #3 |
ok thats what i figured... i had my integy 55t with the endbell adanced ~10* on my crawler... one of these http://integy.com/cgi-bin/webc.cgi/s...d=561&p_catid= and a friends crawler with the same gearing with a integy 55t from RCP... http://rcpcrawlers.com/product.php?p...8&cat=9&page=1 and its a decent ammount slower. But with the info you gave me i think i have found my brushless... its the same size as the CrawlerMaster and 1290KV and an outrunner. |
03-11-2008, 03:53 PM | #4 |
Newbie Join Date: Feb 2008 Location: Iceland
I'm a newbie in the crawler section but I have been running touring (and stadium truck) since last century and I thought that would hurt the motor if one runs it backwards with timeing other than 0°. Could someone set me strait. Yours Spot(T) |
03-11-2008, 04:14 PM | #5 |
| You are correct. It is definitely not recommended, even in the crawler world.
03-11-2008, 06:15 PM | #6 |
really what would be wrong with say putting the endbell to -10* timing... then flopping the power leads?
03-11-2008, 06:40 PM | #7 |
As long as the timing is advanced the right way, it wont hurt anything. You will have more brush wear in reverse, but less in forward locomotion with about 7 degrees of timing. You will also have less power in reverse. I tend to keep mine timed at 0 for best all around performance.
03-11-2008, 06:42 PM | #8 | |
I just know that flopping the power leads on a motor with timing advance makes it work harder to make the same power and can damage it in time. Here's some explanation in this thread. | |
03-11-2008, 06:44 PM | #9 |
rotating the can 170 degrees would have the same effect as 10* neg timing and reversing the power leads. Mostly you just want to make sure it spins faster in forward than in reverse. |
03-11-2008, 06:47 PM | #10 |
| Gotcha, thanks John. I never did much racing so I never got into tuning motors. It never made sense why 170* should be different than -10*, now I know.
