03-18-2008, 12:35 AM | #1 |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
| *No Battery* message w/battery connected to charger?
Here are the specs first: Duratrax Piranha Digital Peak Charger SMC 4200mAh 7.2V battery (dedicated in gwagon) Venom 3600mAh 7.2V battery (dedicated in Rover) Piranha 2000mAh 7.2V battery (spare battery) Tamiya connectors Often, when I connect the battery to charge I get a "no battery" signal on the charger. I check and double check the connection and usually doesnt help. Sometimes I grab the connected tamiya connector and tweak it back and forth to see if I can help the connection and that sometimes works. This happens with any of the three batteries. Also, sometimes I get a "open circuit" message too. Once, maybe twice I got that message only to then get the "no battery" message... My rigs are scale rigs with nothing fancy-typical 2ch stuff, integy 55t or novak 55t motor, moped and tekin rebel 2 esc's. I dont think I need deans connectors, but may be wrong. If you suggest I need them, please tell me why I need better than Tamiya connectors (I would appreciate it). What could be causing the "no battery" or "open curcuit" messages? What things should I look for to prevent it happening as often as it does? |
03-18-2008, 06:49 AM | #2 |
Quarry Creeper Join Date: Oct 2006 Location: kansas city
sounds like it is the connector on the charger to me. I would switch to deans plugs. You can get the copy cat ones on ebay pretty reasonable if you are tight on money. I bought some and they work just fine. Randy |
03-18-2008, 07:55 AM | #3 |
RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
| x2 If you can 'tweak' the connectors around a bit, wiggle them, and that fixes the problem, odds are the connectors are bad/not so good. Try switching connectors, even if you have to get new Tamiya style. But i would suggest Deans Plugs... |
03-19-2008, 12:38 AM | #4 |
Pebble Pounder Join Date: Dec 2007 Location: Torrance
X3 on the Deans connectors, I've seen many Tamiya plugs get so hot they fuse together. That might not be your problem though, there could be a cold joint or broken wires inside the pack. If it is happening on all of your packs it could be the charger's plug or the charger itself. Try borrowing a battery from someone and see if it does the same thing. You should also try charging your batteries on a different charger to see if it is giving you the same error.
03-19-2008, 09:39 AM | #5 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
The other issue I've had with my Pirhana is that the bare wire ends of the plug don't always make good contact with the holders on the charger. Tinning them with solder largely fixed that problem.
03-19-2008, 11:06 AM | #6 |
all good suggestions. thank you! pablo- |
