03-20-2008, 03:16 PM | #1 |
Rock Stacker Join Date: Oct 2007 Location: a house
| motor is smoking
ok i built my new crawler and i put a rooster 55t combo in is hooked everything up and i was trying to get it to work and i looked od the motor area and there was smoke comming off of it any thoughts by the way i cant get it to go foward or backward |
03-20-2008, 03:28 PM | #2 |
Quarry Creeper Join Date: Mar 2005 Location: hudson (the big city)
couple things. did you program the esc to your transmitter? do you have the esc plugged in the rx properly. also, you may want to check your gear mesh. it could possibly be way to tight.
03-20-2008, 03:30 PM | #3 |
Pebble Pounder Join Date: Dec 2006 Location: Earth
if the motor is smoking, stop buying it cigarettes seriously, was the smoke coming out of the motor when you applied throttle, or just when it was sitting there? if it was when you applied throttle, the only solution I can think of is that the motor has somehow already ate itself. if it was just sitting there, no throttle (aka no power going through it. in other words, not just trimmed to the point where it won't move, but still makes strange noises), then I have no idea what the problem could be |
03-20-2008, 03:36 PM | #4 |
i will check the gear i am running a dx3r with a six cell but i cant get the trim set for the motor either
03-20-2008, 03:49 PM | #5 |
Newbie Join Date: Feb 2008 Location: Tacoma
Without seeing the truck my firt guess would be something is binding in your drive train and you probably toasted the motor. Can you spin the wheels/drive train by hand with the motor installed? When you take the motor out does it roll freely? As for the smoke are you certain it was the motor? Could it have been the wires, or the capacators on the motor? To check motor take it out of the truck, connect it to the ESC and see if it spins. Unfortunately letting the magic smoke of out something electronic is never good. |
03-20-2008, 04:02 PM | #6 |
RCC Addict Join Date: Aug 2007 Location: Toronto, Canada
Get some marshmallows out and have a campfire.. hehe. Ummm yeah smoke is a bad thing. Possibly post some pics of how you have it wired up. Possibly a wire shorted onto something.. I dunno. You said 6 cell.. what cell type are they (2/3a,SC etc.)? Keep us posted. |
03-20-2008, 06:24 PM | #7 |
they are the split hump pack from the crawler store i think 2/3a they are the small ones i am pretty sure the smoke was comming from the motor it was at the fery front of the motor i will tru to get pics if i can of the wiering and i can not get the trim set for the motor?esc on the dx3r
03-21-2008, 10:16 AM | #8 |
Quarry Creeper Join Date: May 2007 Location: Seattle
You cannot get the throttle channel trimmed ... but without the motor going forward or backward that's impossible to do anyway. Try spinning the motor by hand, rotate the spur gear with your hand and it should turn the motor. It's possible you could have had you throttle trim slightly out of adjustment and it was trying to move the motor, but only very slowly - and you cooked a brush. Spinning the motor over should get it off the burnt spot and it might work. But I would take a few steps back and ensure you've got everything connected and setup correctly, so ..... 1. Disconnect the motor. 2. Make sure you have the ESC plugged into Channel 2 on your receiver. 3. Go through the setup instructions for the ESC. 4. Reconnect the motor. ( + wire goes on one side, - wire goes on the other side of the motor's hood. ) 5. Spin it by hand and see if you can get it to work with the throttle trigger on the radio. If it does not work it might be easier for you to just take it to a local hobby shop and let someone take a quick look at it. Could be something as simple as a hung brush, or something as complicated as a bad motor. Sounds like you are still learning so having a more experienced eye take a peek at it will probably save you some time and grief in the long run. |
03-21-2008, 10:39 AM | #9 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
aahh.. magic smoke.. every electronic devise comes loaded with it.. but after it emits it it never works again! "diodes roasting on an open fire.... The scent of buring silicone nippin at your nose...." check that your gears aren't meshed to tight... it'll make a screamin noise and smoke will follow.. or you just have a bad motor. |
03-21-2008, 03:12 PM | #10 |
well i got the trim set and the gear mesh is pritty lose the motor will spin the tranny out of the truck but it acts like it is locked up when the drive shafts are hooked to the axles any thoughts
03-22-2008, 12:09 AM | #11 |
If the motor spins out of the truck, but not in, then your motor screws are too long and hitting on the arm. Normally something like a 3x6 screw is about right.
