03-21-2008, 02:38 PM | #1 |
Quarry Creeper Join Date: Jan 2007 Location: L.I.
| nomadio react issues
when going in reverse and steering at same time the esc brakes, but when going in reverse without touching steering I get reverse. when going foward and steering truck has foward movement. tried a AM radio and a FM radio and everything works fine. also tried a different esc get same results (braking when using reverse and steering simutaniously). it appears the problem is with my react either tranceiver or radio. Any body else have issues with there nomadio? |
03-21-2008, 03:09 PM | #2 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
Sounds like your pulling all the power for the bec and causing it to fail safe.What servo's and battery are you useing?
03-21-2008, 03:48 PM | #3 |
using 2 servo's (mg995) and 2s 1550 lipo's. but why does it work when using my cheap Am or Fm radio? |
03-21-2008, 03:52 PM | #4 |
Rock Stacker Join Date: Mar 2008 Location: Arvada
I was having same problem with mine as well I had to put low torq servo back in my truck
03-21-2008, 03:53 PM | #5 |
what esc are you using?
03-21-2008, 05:00 PM | #6 |
currently using novak crawler rooster, tried my mamba max with same results. can't be servo's, I disconnected my servo's and pulled trigger in reverse and tried steering, saw the brake light come on on esc. |
03-21-2008, 05:27 PM | #7 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Did you accidentally mix the two channels? It's easy to get things out of whack with the React if you aren't careful. |
03-21-2008, 07:06 PM | #8 |
Rock Crawler Join Date: Jan 2006 Location: Colorado Springs
Yep, sounds like some mixing going on. I'm using my XS3 with my Hi-lift and while setting up the new model, I inadvertantly copied another model I use for my 1/5th bike. Long story short, everytime I would hit reverse, the 3rd channel would try to shift the tranny and I would just sit there and spin in neutral. Check for mixing! |
03-21-2008, 07:43 PM | #9 |
Jason Thank You, you just saved me $350 (was about to go to lhs and get dx3r) started checking all settings, found brake mixing, for some odd reason it was set to rear (don't ever remember setting it that way). turned brake mixing off now everything works fine. |
