03-26-2008, 10:06 AM | #1 |
Newbie Join Date: Mar 2008 Location: Auburn
| Venom Wire Solder - Which is +?
I'm putting Deans plugs on my charger. It's a Venom if that matters....How do I know which wire is Positive? Both are black, one has writing on it about volts and specs...the other is blank. I'm assuming the writing means it's positive and the blank is negative...but I've never done it before, and don't want to ruin my battery. Thanks. |
03-26-2008, 10:07 AM | #2 |
Look at the case, may be a stamped + on it.
03-26-2008, 10:11 AM | #3 |
That was fast... Ok..I see a very small - and + with a small circle and half circle in the middle on the backside label. That matches up to writing side + and no writing -. No guts, no glory. Thanks. |
03-26-2008, 10:29 AM | #4 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
That's funny! I never knew there was a band RacerX... |
03-26-2008, 10:48 AM | #5 |
Rock Stacker Join Date: Mar 2008 Location: Arvada
check how battery plug was orig. red poss, black neg or look at batt plugs Im guesing it had tamiya style connectors look at end of connecor pos end is square neg. is round let me know if you still need help |
