04-15-2008, 04:07 PM | #1 |
I wanna be Dave Join Date: Jun 2007 Location: Canada, eh.
| Anyone else experience this?
Vague title to tempt you to read further :-P I recently installed my Castle BEC with my Mamba Max. Previously, I had been running the BEC with my Novak Rooster and everything worked as it should. Now with my Mamba Max, everything works but with a slight twist, the switch on my MM still works. Electronic set-up is as follows: Spektrum DX3r tx Spektrum SR3100 rx Hitec 5955tg steering servo (plugged into Channel 1) MM esc (red wire removed and plugged into Channel 2) MM BEC (plugged into battery/bind port) When I plug in a battery, the servo powers up and I can control the steering with my rx. However, I have to actually switch on the esc to have throttle. From what I've read and what I experienced with my Rooster Crawler esc, plugging in the battery should power up everything, not just the servos. The BEC is wired up through an inline Dean's plug, installed by JRH, so I'm confident that isn't an issue. I'm happy if I have a switch for my esc, just want to make sure I'm not damaging it. I've asked Joe at CC about this, and he's also on it, but I figured the more input, the better! |
04-15-2008, 04:46 PM | #2 |
Rock Stacker Join Date: Aug 2007 Location: Canada
I got the same setup as you, MM and CC BEC and My switch is still working, just like your setup.... It is my believe that this is normal from what I read...
04-15-2008, 05:14 PM | #3 |
Quarry Creeper Join Date: Aug 2007 Location: United States
That is how the BEC works, It bypasses the ESC and sends power directly to the servos. So as soon as you plug in the battery the power goes to the servos. Then to get throttle control you must switch the ESC to the on position.
04-15-2008, 05:18 PM | #4 |
Thanks for the replies guys. It makes sense to me too, since the orange signal wire is still connected. However, with my rooster esc and bec, plugging in a battery powered up both the servo and esc. In e-mailing with Joe at CC, he also indicated that still having an operational switch with an external BEC was unusual. Just wanted to check and make sure I didn't fry $200 of electronics with a $20 BEC |
04-15-2008, 07:30 PM | #5 |
The way Castle built things, the mamba won't arm until the internal BEC is turned on. I just hardwire the ESC on and remove the red wire so that the external BEC power doesn't get into the MM.
04-15-2008, 07:47 PM | #6 |
Pebble Pounder Join Date: Sep 2007 Location: Not where i should be
| Thats what i did and it works fine, however sometimes when the voltage gets low and the rig is in a climb or bind i've noticed that i lose control of the throttle untill the load is taken of the motor.
04-16-2008, 07:26 AM | #7 |
| Hmm, ok. I like having the switch though, so I think I'll just leave it rather than removing it and hardwiring my esc on. As long as my BEC is working and not smoking any electronics, I'm happy Thanks again guys!
04-16-2008, 04:59 PM | #8 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
I run the same setup in my Clod... But I put an RX switch onto the BEC as well and have 2 switches to turn on when I run... Had the same thing with my RX packs on the ol' EVX.. It's kinds like having a dbl safety to ensure it never gets accidentally turned on as I run LiPo...;)
