| | #1 |
| Newbie Join Date: Nov 2007 Location: Japan
| Something terrible just happen:-( My antena cable has just been cut by accident! The radio system is 27MHz. 3 cm still are connected to the reciver. Is it ok to just strip both ends and reconnect them with a metal sleeve? OriginalEuipmentManufacturers always recommend not to cut an antena cable, but this just happen by accident. Thanks for your help |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
| You colud try connecting it that way, but you might loose a little range. If you have some soldering skills, I would suggest going to the hobby store and purchasing a new antenna wire the same length as the original wire (if its longer, cut to the correct length) and attach it to the same spot as the current wire. |
| | #3 |
| Ok, i will try with the sleeve first and see how the range has been changed. THANKS for the advice. |
| | #4 |
| Newbie Join Date: Feb 2007 Location: Gainesville
| here is you a replacement just solder it in place on the board you shouldn't lose any range if you just replace it http://www3.towerhobbies.com/cgi-bin...?&I=LXPWA0&P=7 |
| | #5 |
| Newbie Join Date: Apr 2008 Location: vancouver
| is range really that important? most guys are just 5 feet away when crawling |
| | #6 |
| Rock Crawler Join Date: Apr 2007 Location: Denverish
| I'd replace it. Your LHS should be able to do it for a nominal fee if you don't feel comfortable soldering. If you splice it you also run the risk of increased glitching. |
| | #7 |
| I just got an spare antena from the LHS. Have to check the reciver inside to estimate if I can handle the soledering work by myself |
| | #8 |
| Use a very small tip on a very hot iron. Works great. |
| Thread Tools | |
| Display Modes | |
