07-04-2005, 04:11 PM | #1 |
Newbie Join Date: Dec 2004 Location: Dallas
| 1 or 2 Batteries
For you guys running clods do you run a single main battery or 2?
07-04-2005, 04:31 PM | #2 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
Not just the clods, but most of us all only run 1 battery.
07-04-2005, 10:06 PM | #3 |
there are no crawlers that i have run 12 cells on and liked. the weight is a major downfall. the only way i would want to run that many volts is if i ran a 3 or 4 cell lipo. you could have killer runtime with a high wind motor and lots of torque too with higher voltage pack. the motor would need to spin at around 500-700 rpm per volt to use that much voltage though, and lathe motors(55t) usually spin at 1000 rpm per volt. a better solution is to use 6 cells and just make your rig light everwhere you can. its a fine line between light and weak in some cases. |
