05-10-2008, 12:19 AM | #1 |
Newbie Join Date: Apr 2008 Location: federal way
| 6cell conversion to 7 cell?
First off I have a 6-cell 3300mah matchpack ,and was wondering if I went to a 7-cell ,would I gain anything? would it be to much for speed control and servo?
05-10-2008, 01:07 AM | #2 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
Depends on what speed control and servo you have. We'll need a little more info to help you out. Generally, 7 cells will get you more wheelspeed and power.
05-10-2008, 02:33 AM | #3 |
I am running the rooster crawler ,and the servo is the ds8711,just want to make sure i wont damage speed control or servo? these things can get expensive.....
05-10-2008, 02:46 AM | #4 |
Rock Stacker Join Date: Mar 2007 Location: portland
If you run it parallel you will gain mh, if you run it series you will gain voltage... The ESC should handle up to 12 cells... Check the manufactures web site and or owners manual |
05-10-2008, 04:45 AM | #5 |
Newbie Join Date: Feb 2008 Location: England
The rooster crawler esc can handle 7 Ni-Cd/Ni-MH cells (1.2V/cell) or 2 Li-Poly cells So you will be allright, It will increase your torque and speed, If the receiver is powered off the esc the servo will be protected by the esc's Bec.
05-10-2008, 09:44 AM | #6 |
| what does it mean when you say powered off the esc,do i have to have a reciever pack?
05-10-2008, 12:59 PM | #7 |
| Nope, all he is saying is that the servo won't be affected by the extra volts. You're fine, go for it. That ESC is rated for 7 cells, not 12 as someone else said. Check out some of the 7 cell 1500mah saddle packs for axle mounting if you're going to buy a new pack.
