05-11-2008, 07:33 AM | #1 |
Quarry Creeper Join Date: Jan 2008 Location: Dahlonega
| Ax10 servo
I got a ax10 rtr and i was noticing yesterday when you put it in a bind the servo kinda looses its power. What would be a good servo to up grade to?
05-11-2008, 08:20 AM | #2 | |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
The Hitec 645mg is on the lower end of torque at 133oz/inch, but also the most inexpensive (around $40 new). If your wallet doesn't have limits, then you have some options. JR makes some nice high torque servos like the 9000t and I can't remember the other number (I think 8751?). Hitec has the 5990, 5955, and 5995. All of the above are over 300oz/inch of torque @ 6volts. They are all over $100 a piece and they can suck up a good bit of power. | |
05-11-2008, 09:17 AM | #3 |
Thanks man, I am going to go with the hitec 645mg for now. Untill i can afford a really good one. thanks for the help SVEN |
05-11-2008, 09:45 AM | #4 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
You may also want to consider the Hobbico CS170. Its the same servo as the Hitec 5955TG but doesn't have the programability (never known a crawler who uses that feature). Tower Hobbies also has the same servo as the TS-170. Its still spend and probably overkill, but I noticed a big jump in performance. Depending on your ESC, you may also want to get an external BEC, which may make this somewhat un-affordable for you. I'll second the suggestion of the Hitec 645MG as a cheap option. They're good, just not as powerful.
05-11-2008, 09:59 AM | #5 |
What is a bec? I have about 80 to 100 dollars to play with right now.
05-13-2008, 10:07 PM | #6 | |
Rock Crawler Join Date: May 2008 Location: The Beautiful South
05-13-2008, 10:21 PM | #7 |
well i broke mine after about 1 pack through it, so i kinda haft to up grade, I will post what ever i come up with |
05-14-2008, 08:22 AM | #8 |
RCC Addict Join Date: Jan 2008 Location: www.rccrawler.com
Hey but how much can the RTR AX10 ESC handle anyway?Wouldn't a nice $100 or over servo just put too much strain on that stock ESC? I have some RTR AX10 questions like the one above ... generally How good is that ESC ? |
05-14-2008, 08:54 AM | #9 |
A BEC is a handy little device that allows you to power the radio and servo independently of the power output from the BEC. Most ESCs only provide a few amps, which is fine if you're using wimpy servos, but won't cut it in a crawler. My Hobbico CS170 can pull down 5-7 amps when maxed out. Castle Creations makes a really nice BEC that you can get for $20-25. The BEC takes the ESC completely out of the equation, and allows you to run whatever you want. It also provides a little more voltage to the servo, allowing you to get a little more power. See my other post for thoughts on a good servo.
06-08-2008, 08:04 AM | #10 | |
A link would be awesome, given that I have no idea what you are talking about, and their website does not have a search function. Tia. | |
06-08-2008, 08:29 AM | #11 | |
http://www.horizonhobby.com/Products...rodID=CSECCBEC | |
06-08-2008, 03:23 PM | #12 |
^^^thanks
06-08-2008, 08:37 PM | #13 | |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
