| | #1 |
| Pebble Pounder Join Date: Jul 2007 Location: Sachse TX
| This is what I have. I run a Super. Front steer, Rear steer, Throttle, and a servo for DIG. I use all Four Channels on my React. I want to run a Sidewinder ESC to be able to use the Lipo 3S. I would like to add a BEC, beacuse the Sidewinder only puts 5.6V to the servos. Question: How can I install a BEC and still use my 4th channel on my Nomadio React? Thanks in advance for any help. |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Aug 2005 Location: VARCOR
| Is it the V2 RX? There should be a separate plug labeled BATT. That is where your BEC plugs in. It shouldn't affect any of your channels. |
| | #3 |
| RCC Addict ![]() Join Date: Sep 2007 Location: WHEAT RIDGE, CO
| Purchase a "Y" harrness. Plug the BEC (powered off the battery) into one side, the servo in the other side and JUST the signal-wire into the receiver. |
| | #4 | |
Can I just plug the BEC in to the BATT recep. | |
| | #5 |
| Ah, than it is different than the one I had experience with. That one had the four channels in a row, then a BATT plug off to the side. Sorry I can't help. |
| | #6 |
| Pebble Pounder Join Date: Apr 2008 Location: Indiana
| Use a Y-harness to the 4-ch position, this is the Nomadio stated method. Do not plug a battery into the batt sensor spot. |
| | #7 | |
Then plug in the servo and BEC into the Y harness and into the 4-ch position? Or plug my BEC and ECS into the Y harness and into the throttle position? | |
| Thread Tools | |
| Display Modes | |
