Thread: wich motor???
Old 07-29-2008, 09:54 AM   #1
Default wich motor???
i am getting a rc4wd tranny on my scaler but in combination with a novak 55t motor it doesn t have no speed anymore , what motor should i take to have still enough torque + some more speed , any sugestions anyone
rookie73 is offline   Reply With Quote
Old 07-29-2008, 10:02 AM   #2
Call John at HH,he will help you out. http://holmeshobbies.com/home.php
KREEPYHEEP is offline   Reply With Quote
Old 07-29-2008, 03:58 PM   #3
I would say the HH-HHH30 or 35 from Holmes Hobbies.
LIKES2CRAWL is offline   Reply With Quote
Old 07-30-2008, 02:25 PM   #4
Default puller
you could do a puller motor from holmes.
ckmehl is offline   Reply With Quote
Old 07-31-2008, 01:10 AM   #5
That puller motor is one hell of a beasty engine , but I think I go for the 35T solution
Thanks for the info guys
Old 07-31-2008, 01:48 AM   #6
Add more volts to the equation. If you geared down the the R2, volt up with a bigger pack. Are you running a 6-cell now? Try an 8 or 9 cell... ONLY if your ESC will work with a bigger pack.
2JSC is offline   Reply With Quote
Old 07-31-2008, 09:09 AM   #7
varcor.org
swell searcher's Avatar
I agree, instead of trying another motor. Try a different pinion or volt up. Which ESC are you running?
On the R2/R2D I had, I ran an Axiom 50T motor with a 22T pinion (I think somewhere around there) and saw an improvement over the stock pinion that comes with the R2/R2D. The biggest improvement was jumping to the 8-cell pack.
swell searcher is offline   Reply With Quote
Old 08-01-2008, 01:08 AM   #8
my esc is a traxxas xl5 so i think it can t hold 8 or even 9 cell battery packs + i haven t got the space because I rejused the battery holder from my wheely king and all the rest of my homemade scale chassis is packed up with other stuff , I could try with the gear ratio to , thanks alot for the info dudes
