06-07-2008, 08:31 PM | #1 |
Pebble Pounder Join Date: May 2008 Location: Mobile, AL
| Gearing on a 7T puller?
I searched but couldn't find anything that answered my question. I'm running a 7T puller, Mamba Max, 11.1 Lipo in an AX10 with the stock tranny. I lost the stock pinion for the AX10 somewhere in the build, lol, and was wondering whats the best gearing for this setup? Thanks, Jakerz |
06-07-2008, 08:44 PM | #2 |
RCC Addict Join Date: Feb 2006 Location: ccxc
not sure....running the rtr gear here. 21t I think and it seems fine...decent wheelspeed.
06-07-2008, 08:44 PM | #3 |
Rock Crawler Join Date: Dec 2007 Location: Shreveport, La
running a 7t puller on 3s with axial tranny & 13t pinion on one of mine, it hauls ass too ran it at a comp today and it did fine |
06-07-2008, 08:51 PM | #4 |
Wherever you want really. I say start with a 14t and see how you like it.
06-07-2008, 08:51 PM | #5 |
I run a 10t at 18/81 on a 3 cell. Pretty quick and pleanty of torque. If I had a 7t,I'd probably stick with the same gearing. List of things you will need Yotachumps chromoly 6mm outputs Metal internal gears in the tranny Hardened steel ring and pinion Steel lockers. A slipper will help the stock parts last a little while. |
06-08-2008, 09:08 AM | #6 |
Ok thanks for the info, I'll ride out to the LHS today and pick up some different sizes and experiment alittle bit! Jakerz |
