06-09-2008, 09:19 AM | #1 |
Newbie Join Date: Jun 2007 Location: Chile - Santiago
| Help with ESC Novak Goat y Brushless 18.5 Turn Motor
Hello .. I have a problem with my ESC .. follow the set of manual and left unchecked .. someone has had the experience? I Brushless motor and Novak Goat for Brushless 18.5 .. Excuse my bad English ... Greetings ... |
06-09-2008, 09:26 AM | #2 |
What is the problem? don't understand waht you are asking, pm me in spanish maybe i can help out |
06-09-2008, 11:12 AM | #3 |
Ok guys, it seems there problem is the drag brake, they bought goat esc only and added the 18.5 novak motor later, they have tried to program the drag brake with no luck.
06-09-2008, 12:19 PM | #4 |
Quarry Creeper Join Date: Mar 2008 Location: Redlands
I would have him try to setup the ESC again, perform the inital setup with the motor soldered and sensor wires connected.
06-09-2008, 12:42 PM | #5 |
Thanks ds, i'll pass it on to them,i am not much of help to them, as i have 3 goat systems and mine were pretty much install and play haven't even touched any settings as i love the way these work out of the box.
06-09-2008, 12:56 PM | #6 |
Rock Crawler Join Date: Jul 2006 Location: Hobbywing
If you still have problems, try turning the Dead Band "all the way up" to setting 5.
06-09-2008, 01:02 PM | #7 |
Charlie, Any tips for setting the drag brake up? right now I have it set to 10 (highest setting) and it will roll on the slightest angle. Almost like no drag brake at all. |
06-09-2008, 01:18 PM | #8 |
darkstar, are you running a goat system or just a goat esc and brushed motor? what pinion and spur gear?
06-09-2008, 01:21 PM | #9 |
Goat system. stock gearing right now. I was also using the stock gearing on my Rooster system as well, and the drag brake was awesome, and worked very well.
