06-21-2008, 04:59 AM | #1 |
Rock Stacker Join Date: Sep 2007 Location: !!!
| quick lipo question
im just about to get into lipo and im not sure what the "c" means and if it make much differents ive seen 15c 18c 20c 25c im running a berg with 2 55t integy and a mamba max ive seen some 2400 mah 11.4 15c that i like but after doing a serch it seems that most use 20c whats it all about |
06-22-2008, 02:02 AM | #2 |
Quarry Creeper Join Date: Nov 2005 Location: Planet Earth
C just stands for capacity so the capacity is multiplied by the number in front of it.
06-22-2008, 04:23 AM | #3 |
I wanna be Dave Join Date: Dec 2007 Location: Florida
floogldood, that's a good one... The "C" rating tells you how much current it is safe to draw from your battery. It's expressed in terms of the capacity C. The C rating doesn't mean your motor will go faster or run for longer. It just means that if you ever want to use more current, by using the battery with a different motor or a bigger pinion, the 25C battery will allow more than the 15C version. |
06-22-2008, 08:19 AM | #4 |
thanx mikey that'll do |
06-22-2008, 11:50 AM | #5 |
ΜΟΛΩΝ ΛΑΒΕ Join Date: Dec 2006 Location: In tha Bush of Louisiana
06-22-2008, 04:32 PM | #6 |
Newbie Join Date: Sep 2006 Location: Scotland
06-23-2008, 01:40 AM | #7 |
It is very simple math. 20 C stands for 20 times capacity. a 2400 mah 20C = 48 amps. OR a 2C x 2400 mah = 4.8 amps. |
06-23-2008, 02:30 AM | #8 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
Ya the "C" rating is mulitplied by the capacity to get the constant amp draw. But it will absolutely effect runtime and power. A good analogy... If you have a pack that can handle 50 amps constant and always pull a constant of 50 amps, then the pack wont last long or have good cycle life even though it can handle it. Same if you were to drive your real car at top speed everywhere... the engine wouldn't last as long. But if you have a pack that can handle a constant of 75 amps and pull a constant of 50 amps, longer runtimes, more power and cycle life. But beware, there are alot of false rated packs out there... Stick with name brands and you will never have any issues with false ratings. The brands I would stick with are: Polly Quest, Thunderpower, Polly RC Hyperion, and Elite. |
06-23-2008, 02:53 AM | #9 |
Rock Crawler Join Date: Jan 2007 Location: Secret Crawl Location Deep In England
J4son, Is yer bannana built yet? Matt |
