| | #1 |
| Quarry Creeper Join Date: Apr 2008 Location: dallas
| Hi all. i have been reading these threads for the past few weeks.. My rig is running a 3cell lipo, integy55 turn, Tekin Fxr, Spectrum sr3000, Hitec 645mg... I received my Castle Bec unit yesterday and installed it as followed... soldered the two loose wires off the Bec to the battery wires coming from the ESC per the instructions.. then plugged the BEC into the "batt" port on my rx. then removed the red wire that runs from the esc into the Rx. when i power everything on the steering works, but im getting no response from the ESC.. no lights, nothing.. Im assuming this is because I removed the red wire... ???? Any help would be appreciated.. Thanks.. |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Aug 2005 Location: VARCOR
| Just to check the simple stuff...............you did turn the ESC on correct? Just have to check because now the steering is getting juice from the BEC, not the ESC, so it is easy to think everything is on because the steering works, but in reality it isn't. |
| | #3 |
| I wanna be Dave ![]() Join Date: Jan 2004 Location: Detroit
| guys in our club found you had to set the ESC up first then remove the red wire and hook the CC Bec up. |
| | #4 |
| Well thanks for the quick reply.... honestly I have no idea whether i still flipped the switch on the ESC.. But that will be the FIRST thing I check when i get off Work!!.. |
| | #5 |
| Thanks binary, that will be the SECOND thing I try when i get off work!!! Thanks. |
| | #6 |
| But im not sure about that second one... The ESC was setup... I had been running it previously. |
| | #7 |
| LOL.. i called my wife from work and told her to mess with my rig... Thanks Robb you were right... i forgot late last night the BEc was powering the steering now... flipped the switch on the ESC and everything powered on... |
| | #8 |
| Whycome U no have tattoo? ![]() Join Date: Feb 2008 Location: Tekin, ID
| LOL, damn switches! |
| | #9 |
| Problem solved!!!! Im an idiot and forgot to flip the esc switch... Absolutely brilliant... But my glitching problem in tough binds has been solved as well!!! I recommend the Castle BEC to everyone!!!! Buy it, use it. . . |
| Thread Tools | |
| Display Modes | |
