Thread: Will my charger charge this?
Old 07-03-2008, 02:15 PM   #1
Default Will my charger charge this?
OK so here is the deal. JeepinDoug and I built a 9 cell battery pack last night for my Axial. Well on the way home I started thinking about how many amps this batt will out out. 10.8!!!!! The problem is my charger has a max rating of 9.6. Will the charger stll work with this? I really don't want to have to go buy another charger, but if I have to, I guess I will.
Thanks
Dima
Flatty is offline   Reply With Quote
Old 07-03-2008, 03:09 PM   #2
what charger is it?
I don't know if they use 9.6 as max voltage due to the internal components and wire, but I would assume they build a little safety factor into the charger so 10.8 may be doable. Watch the temps and see what happens.
bent70 is offline   Reply With Quote
Old 07-03-2008, 04:38 PM   #3
You're going to need a new charger, that one won't fully charge the 10.8v.
mysharona is offline   Reply With Quote
