Thread: Moped failed on a 11.1v 2200LiPo!!!
Old 07-05-2008, 07:35 AM   #1
Exclamation Moped failed on a 11.1v 2200LiPo!!!
This Moped served me well with a standard 4200mah 6cell Intellect but crapped its guts on a 11.1v LiPo ...Just a warning !!!!!
TheHeadHunter is offline   Reply With Quote
Old 07-05-2008, 07:37 AM   #2
littleskull99's Avatar
Mopeds have a 6 cell limit dont they? I run mine on 7 cell and it gets a little hot.
Did you even get to pull away?
Matt
littleskull99 is offline   Reply With Quote
Old 07-05-2008, 12:11 PM   #3
I think the limit is 7, but I never got the nerve to try it.
Jamus is offline   Reply With Quote
Old 07-05-2008, 12:32 PM   #4
Matt
the lights did some strobe impression then stayed on and switched off ,next I tried the on/off switch again and no lights went on until I pushed the on position harder that made some contact and the Clod almost back flipped out of my hands ...smoke screen and thats it :-P
I never read something about this being tried here so far ...there you go!
Old 07-05-2008, 01:09 PM   #5
Kamikaze's Avatar
Wow.....they should put some kind of warning on the box that says somehing like a 7 cell NiMh limit. I guess its there fault cause they dont convert that to 8.4 volts........
Kamikaze is offline   Reply With Quote
Old 07-06-2008, 09:50 PM   #6
@HeadHunter: The specs on the Moped clearly state it is only rated to 8.4V my friend:
Input Voltage: 4.8v-8.4v (4-7cells)
"ON" resistance: 0.00056 OHM
Impulse Current of MOSFET: 70A
PWM Frequency: 2k - 4KHz
BEC output voltage: 5.0v (2A)
Tobit is offline   Reply With Quote
Old 07-07-2008, 08:28 PM   #7
Because most people can read the box.
Soya is offline   Reply With Quote
Old 07-07-2008, 08:42 PM   #8
Yup, it's in Black & White.. literally.
Old 07-07-2008, 08:50 PM   #9
~The Scale Shop~
STANG KILLA SS's Avatar
i put mine on 7 cells once, it got all gittery and reverse always went out. put the same esc back on 6 cells and it worked perfect again.
Old 07-07-2008, 09:15 PM   #10
I ran mine numerous times on 9 cells (before switching to a Sidewinder) with no issues. But I had the red wire pulled and was using a CC BEC. I read somewhere that the ESC's BEC causes it to get hot trying to use the higher voltage. By pulling the red wire on the ESC, I eliminated the BEC. Maybe it's luck,but I have had no issues with it.
jcnalley is offline   Reply With Quote
Old 07-14-2008, 03:12 PM   #11
The box LOL ....have you even used one??? ...4to7cells non LiPo looks like you cant read
I felt like trying it regardless to converting NiMH specs to LiPo and making sense of that...
Some things need to be tested ....like the RTR AX-10 ESC do you think everyone read a whole bunch of in depth LiPo info before they went ahead and tried it with 3 cell L's...
are you suggesting he didn't read the box too ???
Old 07-14-2008, 03:15 PM   #12
It's in black and white literally that it's for 4-7 NiMH cells Sherlock
Old 07-14-2008, 03:18 PM   #13
It was worth trying LOL $30 ...my lunch money
How do ya think people found out that it can take up to 8.4volts???
They tried it
Old 07-14-2008, 03:22 PM   #14
I'm Dracula, Bitch.
JeremyH's Avatar
You eat a lot for lunch...
JeremyH is offline   Reply With Quote
Old 07-14-2008, 04:06 PM   #15
Old 07-14-2008, 04:20 PM   #16
7 NiMH cells always equals 8.4V, it has never been, nor will it ever be, any different. Why is your ignorance the fault of others or the box?? 8.4V max. is regardless of battery type.
Old 07-14-2008, 04:21 PM   #17
because they read the fuggin box. 8.4V = 7 cells, SHERLOCK.
Old 07-14-2008, 05:17 PM   #18
You are amazing - WOWClick the image to open in full size.
ever heard of sarcasm ?
Old 07-14-2008, 05:31 PM   #19
PapaGriz Yo
Grizzly4x4's Avatar
I don't think he ever complained that it burned up.....
Who gives a crap what the box says? Lots of people run too many volts to the ESC to see if it will work. I think he was just trying to state that 11.1V is too much.
Grizzly4x4 is offline   Reply With Quote
Old 07-14-2008, 05:33 PM   #20
It's a setup!
jason's Avatar
Technically the box says 4-7 cells.
He's was only running 3 cells when it crapped out.
jason is offline   Reply With Quote
