07-18-2008, 10:30 PM | #1 |
Pebble Pounder Join Date: Mar 2008 Location: yes
| CC BEC FRIED......again!
I have a castle bec that has been repaired once. It stopped providing power entirely but still showed the l.e.d. that is supposed to denote proper function. This has happened a second time and I need to know if I am doing something wrong. I have the cc bec wired in parallel with my main battery (a 2s 1900mah lipo sometimes a 3s 800mah lipo). I have the other cable (the three wire one) plugged into the aux port (not the battery port...that will initiate the reciever to bind mode) on my spektrum ar6000 reciever. The cc bec will not connect via my castlelink to my pc. Also I have put a capacitor on my reciever to smooth out the the voltage and the bec worked perfectly (after the first repair) for over a month then it just failed. No smoke. No sparks. No more power.
07-18-2008, 10:51 PM | #2 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
| I use a AR6000 with my DX7, and use the BATT port without issue. Why exactly do you not use the BATT port?
07-19-2008, 05:45 PM | #3 |
Quarry Creeper Join Date: Sep 2007 Location: Carlisle
get in contact with castles creations they have great customer support. I had a similar problem and they took care of it for me. they kept sending me new bec's till we figured out my problem. it only took 4-5 bec's lol
07-23-2008, 07:52 PM | #4 |
Newbie Join Date: Jun 2008 Location: berry
cc working on the problem with the binding port. They going to have the bec fixed so you can use it without it binding. Says that on their website.
07-24-2008, 10:06 PM | #5 |
Pebble Pounder Join Date: Feb 2008 Location: Gonzales
I have one that jacked up need to send it in........:-( |
07-26-2008, 05:35 PM | #6 | |
Send it back in to castle. What servo are you using? What is the setup otherwise? | |
