07-20-2008, 04:56 PM | #1 |
Quarry Creeper Join Date: Feb 2008 Location: Lagrange
| dx6 question
I picked up a dx6 from my LHS and got home and looked at it while its charging.. My question is can i set the throttle up on the left stick left and right instead of up and down since it has the spring to self center? |
07-20-2008, 05:04 PM | #2 |
Rock Crawler Join Date: Jun 2007 Location: oVER ThErE
| Yes you can use any channel you like. I have my throttle on the right stick, front steering on the right stick, rear steering on left stick and dig on the left stick...
07-20-2008, 05:12 PM | #3 |
Thanks Sinastir for the help...I have never had one with this many options and all so I really don't know where to start besides charging the battery |
07-20-2008, 05:46 PM | #4 |
| I know and just many sure you adjust your servo throws. That way you will not burn up your servos. Just read the instructions and play with it... If you need help let me know... |
07-20-2008, 08:36 PM | #5 |
Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
I also use a dx6 for crawling, it works sweet....... there are so many options to choose from...i use the elev channel for throttle and the rudder channel for steering and when using dig i mixed the 2 toggles I have a few threads on here i saved so if ya need them let me know. |
07-20-2008, 09:01 PM | #6 |
Yeah if you got a thread on mixing the toggles i might need that..Thanks guys |
