07-20-2008, 11:55 PM | #1 |
Newbie Join Date: May 2007 Location: Frisco now
| Lipo Question
I wanted to buy a lipo battery and charger . My question is how do you take care of the battery to make it last for awhile? how do i store it when i dont use it for a week or more? Thanks for your help Marc |
07-21-2008, 01:22 AM | #2 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
There is really very little maintenance required besides ballancing while charging and making sure you have your lvc set right
07-21-2008, 07:17 AM | #3 |
Rock Stacker Join Date: Sep 2007 Location: French #70 living in Toyohashi
Always charge before storing. Never charge out of sight. Charging on a iron/stainless steel tray is a good idea (help dissipate heat if any, won't burn) Fireproof bags are a good storage idea. Do not let into your car, do not charge into your car, if you charge them on the field, use an extension cord from your car to a place were fire won't damage anything. Bubble wrap them before moving. If they start looking pregnant... plug a 12v light bulb until they are completely empty then discard them. |
07-21-2008, 09:50 AM | #4 |
RCC Addict Join Date: Nov 2007 Location: Nine Mile Falls, WA
Here's from our Li-Po care page on our website: Connection: You must be sure that the correct polarity is observed when connecting battery packs to charger or speed controller. PINK / RED = POSITIVE (+) BLUE / BLACK = NEGATIVE (-) Charging: Lithium Polymer batteries have specific charging requirements and ONLY chargers rated for Lithium Polymer cells may be used. The best chargers are those which require the user to manually select cell count and charge rate for each pack of cells, then automatically check to see that the settings are correct. The Hyperion EOS Charger line belongs to this category. Chargers which use only automatic detection of cell count (and on that basis set charge voltage) are prone to error, and can damage cells or cause a fire due to over-voltage charging of cells. We recommend that these chargers be set manually, if used. Other chargers are set manually, but do not include a safety circuit to oversee that setting. These are prone to user error, and should also be checked very carefully to insure proper use. Lithium CC/CV chargers, like those in the Hyperion EOS Charger line, must be used. These charge initially at a constant 4.2V and constant 1C rate, then taper the charge rate as the battery nears full capacity. Cells are about 90% charged in one hour, and can be left connected for another 20-30 minutes to complete the charge. The maximum permissible charge voltage per cell is 4.2V. The maximum recommended charge rate for Lithium Polymer cells is 1C (ex: 1.5A for a 1500mAh pack). Please do not charge your lithium polymer at any rate higher than 1C. Doing so may reduce the capacity and life cycle of the cells, with very little savings in charge time. Discharging: Any battery including lithium polymer must be discharged within rated current and voltage limits. Failure to do so will result in damage to the battery, at least, and could even cause an accident.
Lithium Polymer Safety Tips: Lithium Polymer cells are a tremendous advance in battery technology for RC use. However, due to the chemistry of lithium cells, there is a possibility of fire if charging is not properly done. It is unavoidable due to the nature of lithium itself. This is no different from many things we use in daily life – knives, kitchen cleaners, automobiles, for a few examples – which are inherently dangerous, but which can be used safely by adhering to simple rules and precautions.
Best regards, Jason |
07-21-2008, 01:20 PM | #5 |
Rock Stacker Join Date: Jun 2008 Location: On Canada
| hey
Someone said "always charge before storing" Not Correct. If stored anymore than a week it is recommended and common practise to store half charged. That is how you will also receive new batteries "half charged" Around 3.85V per cell for any lengthy storage. |
07-21-2008, 01:25 PM | #6 |
Common prctice is that if they are going to sit for a period of 30 days or longer store them at 50% of their rated capacity and then cycle them at least once every 30 days. It is perfectly fine to leave them fully stored for up to 2 to 3 weeks but if longer do as I stated earlier. Jason |
07-21-2008, 03:09 PM | #7 | |
Sorry for my earlier post which made it seem that you need to store at 50% for short term. I'm from Canada and every time hear "storing" I think of over the winter...which is 5 months of storing . A few weeks is fine to store charged. | |
07-21-2008, 07:03 PM | #8 |
Thanks alot guys that was alot of helpfull information
07-22-2008, 09:57 AM | #9 |
| Question was for 1 week or more... (without known limit)
