07-22-2008, 07:09 PM | #1 |
Quarry Creeper Join Date: May 2006 Location: Indiana
| My lipo is messed up...
My 3 cell 11.1V (1250) lipo quits working at 10 volts. Here's my specs: Holmes Revolver Black Quark Pro Car Kokam 3 cell lipo Spektrum radio gear I have the cutoff voltage set at default (2.7V per cell) I only get 10 minutes of run time. Any ideas what's up? |
07-22-2008, 07:19 PM | #2 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
Idont' have the same setup as yours but mine poops out around 10 volts as well. I don't think you want to drop below 3 volts per cell though. Is it fully charging? a 1250 should take at least an hour to charge. My 3s (1320) peaks at 12.55volts w/ a balancer as it is charging. I'm running a 55t/Mamba Max 13/87 and get about 1 1/2 hours ou tof a 1320. Brushless takes more juice though. |
07-22-2008, 08:35 PM | #3 |
It's definitely fully charging. It reads 12.5 volts on my Triton Jr. charger, as well as my meter. The 3V per cell is probably true, but it never even gets to 3V per cell. It poops out long before 9V. What gets me is that I was getting 45 minutes of crawl time with the battery a week ago. Now I get maybe 10 minutes. The battery is probably a year old, but it's only been cycled a dozen times or less. |
07-22-2008, 09:46 PM | #4 |
Do you balance it? You may have a cell that is off the others and triggers the cut-off.
07-22-2008, 09:48 PM | #5 |
Quarry Creeper Join Date: Jan 2006 Location: Henderson
Have you balanced it?
07-22-2008, 09:55 PM | #6 |
Rock Stacker Join Date: Oct 2007 Location: Roanoke
I thought lipo's were not suppose to be taken below 3v per cell........i ran a 2s down to 6.06v.........I balance every time just to be safe.
07-22-2008, 10:09 PM | #7 |
Like I said, It hasn't been taken below 3 V per cell. The Quark defaults to 2.7V, however, it can be set to 3V. 3V per cell would be 9V. It takes a dump at 10-10.5V after 10 minutes of run time. Maybe it's a balance issue. I'll have to check that out. Thanks for the help, guys. |
07-22-2008, 10:23 PM | #8 | |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
How long does it take to charge? | |
07-22-2008, 10:23 PM | #9 |
07-23-2008, 07:03 AM | #10 |
Quarry Creeper Join Date: Jan 2006 Location: Orlando
Some food for thought...unless you're measuring the voltage on the pack while under a load, you're not seeing the same voltage the LVC in the ESC is.
