07-25-2008, 07:16 AM | #1 |
Newbie Join Date: Jan 2008 Location: Austin
| CC-BEC wiring up to TQ3 RX
So last night all excited to power up my new rig, CC-BEC to Batt port, connect ESC(Tekin RB) to #2, connect batteries ...SMOKE and melted insulation on Black wire from RX to ESC and Brown wire from RX to BEC. I pull the plug ASAP and salvage the ECS. Remove the cc-BEC, run set-up on ESC and everything operates perfectly. I then tried removing the Red wire from the ESC, and plugging the cc-BEC back in ...SMOKE. Reconnect without the cc-bec , back to normal. What's wrong? Do I have to rearrange the wire order in the cc-bec RX plug to work with the TQ3 RX. I'm lost on this one. |
07-25-2008, 11:04 AM | #2 |
Rock Crawler Join Date: May 2007 Location: lacey
the second time you did everything correctly, I think what happened is you might have fried the bec when you had the esc power on as well. where did the smoke come from.
