07-30-2008, 10:16 AM | #1 |
Newbie Join Date: Oct 2006 Location: Norway
| Goat problem!
My AX10 with a goat system has a minor problem! It acclerates like hell in reverse, but not in forward. It even goes faster in reverse. What tha fawk is wrong?? |
07-30-2008, 10:41 AM | #2 |
Rock Stacker Join Date: Apr 2008 Location: Tucson
| same problem
i had the same problem with mine. come to find out it was all in my radio. i had the set up wrong in my radio. try stting the foword to the max. and the reverse to about 85%. i had a MX3 with this problem.
07-30-2008, 10:45 AM | #3 |
It's not in my Radio, it has no options! And I've used it before with the same car and same setup. It's only a 2channel hpi:racing transmitter! TF-1 or whatever it's called |
07-30-2008, 10:46 AM | #4 |
You can reverse the throttle on your radio from it's current position.
07-30-2008, 10:59 AM | #5 |
Yeah, but then forward will be reverse and vice versa..
07-30-2008, 11:04 AM | #6 |
Ok, I reversed my motor, and reversed the trottle on my radio. I got the power in forward like I want it BUT, it will drive by itself on neutral position on the throttle. I have to reverse a little bit to make it stop! And that's with the trim turned all the way around!
07-30-2008, 11:27 AM | #7 |
Rock Crawler Join Date: Feb 2008 Location: Nebraska
Sounds like you need to adjust your throttle trim. Move it just enough to get the truck to not move when the throttle is in the neutral position.
07-30-2008, 11:39 AM | #8 |
I know, but I can't adjust it more! |
07-30-2008, 11:52 AM | #9 |
I got it figured out. Doesn't know how though, haha But thanks for the help guys |
07-30-2008, 11:59 AM | #10 |
Suki did you read the instruction that came with your Goat system you can reverse the throttle at the ECS as well. I should have told you that to start with sorry my bad. Try that Last edited by Stormin2u; 07-30-2008 at 12:02 PM. |
07-30-2008, 12:38 PM | #11 |
Yup, read that Look at post #6, that's what I did ;p
