08-01-2008, 11:23 AM | #1 |
Pebble Pounder Join Date: Jun 2006 Location: Melbourne
| Mamba & CC BEC
Right now I have my rig set up with a Mamba Max and also a CC BEC. I don't mind the steering power with the way it is setup, but have never changed the CC BEC to a higher output. Would I see a huge improvement in buying the castle link and bumping the BEC up to 6 volts or should I just take the CC BEC off and sell it since the Mamba puts out the same 5.1 volts as the stock CC BEC?
08-01-2008, 11:58 AM | #2 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
We need more info,What kind of rig,what servo,battery and are you going or running a dig/two servo's?
08-01-2008, 12:44 PM | #3 |
Rock Crawler Join Date: May 2007 Location: lacey
Yes you will see a HUGE difference. also, the MM may put out 5.1 volts like the ccbec, but the bec puts out 10 amps, whereas I believe the mamba puts out somewhere around 1.5. I single High torque servo can draw more than 3 amps.
08-01-2008, 01:00 PM | #4 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
- Yes, 6 volts will produce a noticeable difference. I would buy the link and change the voltage. The issue is not so much the voltage as it is the amperage. The mamba max BEC has low amperage. It might be 5 volts, but the amperage is only 1.5amps (or something similar) where the BEC is 10 amps. 6 volts at 10 amps will give the servo a noticeable boost in performance. |
08-01-2008, 01:26 PM | #5 | |
The LHS wanted to charge me $30 to change the volts on this thing ...might as well buy the castle link for that! | |
08-01-2008, 01:46 PM | #6 | |
Moderator Join Date: Jul 2007 Location: Texas baby!
08-01-2008, 01:46 PM | #7 |
| $30 is ridiculous. Definitely buy you own link. Either that, or see if a local club or forum member near you has one and can do it for free. If you were local member in my area, I would program it for you.
08-01-2008, 02:29 PM | #8 | |
I hate to buy one since I will only use it once...I'll keep checking! | |
08-01-2008, 08:42 PM | #9 |
Rock Stacker Join Date: May 2008 Location: oregon city
if your in oregon i can do it for you.
08-16-2008, 04:03 AM | #10 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
Also John H. will do it for you for a very small fee. Is info is in the vendor section....It takes all of 5 seconds to do it....
08-16-2008, 09:55 AM | #11 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
