08-05-2008, 06:40 PM | #1 |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
| ESC hit a rock
I was running my Berg without a body and rolled it. Not the first time and not the worst one either. My ESC is mounted on top and I think it hit a rock, it won't go forward or backward but still turns the wheels. I was just wondering if it's possible to mess up a speed controller by impacting it on a rock. I don't have an extra one to test and I don't want to buy another if I don't have to. It's a Novak Rooster Crawler if that matters. Thanks for any info.
08-05-2008, 06:57 PM | #2 |
RCC Addict Join Date: Dec 2004 Location: HELL.....
08-05-2008, 07:03 PM | #3 |
Rock Stacker Join Date: May 2008 Location: united states
08-05-2008, 08:31 PM | #4 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
Check the motor wire solder joints. Make sure to check them at both the motor and ESC ends. We know the battery wire connections are still good as (we think) the steering still works. A cold solder joint is vulnerable to a hit. And yes it is possible to damage an electronic device if you whack it hard enough. The most obvious failure being a cracked circuit board or solder joint..... Narly1 |
08-06-2008, 08:23 AM | #5 | |
Quarry Creeper Join Date: Mar 2006 Location: SoCal
Even if your Novak Rooster Crawler is DOA, we offer a replacement program for $39.00 (w/new 120 day warranty): Speed Control Replacement Options Program | |
08-06-2008, 06:18 PM | #6 | |
I checked it out today and found the problem, one of the posts that the receiver plugs into was broken inside the plug. Just to check, that post can be soldered back on, right? | |
08-06-2008, 11:31 PM | #7 |
Quarry Creeper Join Date: Jul 2005 Location: pleasant ridge
yes it can
