08-11-2008, 10:01 AM | #1 |
Quarry Creeper Join Date: Sep 2006 Location: Valpo
| how do you guys mount spektrum antenna?
i just got a dx3r and i saw on spektrum's website that you must mount your antenna in certain ways. how do you guys mount the antenna on your crawlers? thank you for the help.
08-11-2008, 10:29 AM | #2 |
Rock Crawler Join Date: Jun 2007 Location: Great Britain
I just mount mine straight in a tube like I would any other ariel.
08-11-2008, 10:48 AM | #3 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
| I mount mine horizontaly so the body protectects it when rolling.It's poking out the passengers corner of the roof.Range isn't an issue for a comp rig. |
08-11-2008, 12:39 PM | #4 |
Rock Crawler Join Date: Apr 2007 Location: APPLE VALLEY,CALIFORNIA
i run the older spektrum recievers with my DX3r cause you can still cut those down to less then 3",so it just stays under the body....
08-11-2008, 12:53 PM | #5 |
Quarry Creeper Join Date: Oct 2004 Location: illinois
08-11-2008, 12:59 PM | #6 |
Pebble Pounder Join Date: Dec 2007 Location: Montrose
i have not even uncoiled any of my spektrum antana's except on my 5b |
08-11-2008, 01:03 PM | #7 |
Newbie Join Date: Aug 2008 Location: CT, USA
| I keep mine a little stub but completely under the body, so the rx can go under the water level and i have no issues |
08-11-2008, 02:56 PM | #8 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
Usually I just let it flop around until it gets ripped off by something. Then I keep driving and don't worry about it. |
08-12-2008, 04:22 AM | #9 |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
Not a real good picture of it, but.... |
08-12-2008, 07:15 AM | #10 |
I just wire-tied mine to the top chassis brace.
08-12-2008, 04:50 PM | #11 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
i made a piece out of scrap clear plastic and mounted it on top of stock axial battery tray. not the best pic but you can see it at the top of pic |
08-12-2008, 09:23 PM | #12 |
Quarry Creeper Join Date: Dec 2007 Location: ON THE "EDGE"
i opened the receiver and tucked in inside, no issues with glitching.
08-13-2008, 09:08 AM | #13 |
Quarry Creeper Join Date: May 2007 Location: Seattle
You can see mine here. I just CA a piece of antenna tube to my receiver and run the tube horizontal. I do this on all of my cars, crawler or not - no antenna mount required. If the wire is longer I run two tubes, and have it "s" back through the second tube and out. |
08-16-2008, 11:39 AM | #14 |
Pebble Pounder Join Date: Jul 2008 Location: kelowna
Can someone tell me why the ground antennas are so big. I use spektrum air rx's and the antennas are WAY smaller.
08-16-2008, 12:18 PM | #15 |
Depends on the air RX, some of the air receivers have a larger antenna and a remote receiver to gain range. Only the park flyer receivers have smaller antennas but two of them. Ground vehicles need a slightly larger antenna so they have sufficient range because DSM is line of sight. With something in the air you're always flying within line of sight of the radio where the signal is strongest. On the ground you've got a car going up and over things, behind obstacles, behind jumps, etc which can interfere and reduce range. With the smaller receivers (like the ones I run) there is range issue at over 80-100m. The larger antenna resolves this, as long as the user has it going straight up. That is also the reason park flyer receivers have two antennas. You should mount your receiver so one antenna is going toward the right, and the other left, so when you are flying you've always got an antenna that is open to the radio and not blinded by the airframe. The AR7000 has two 30mm antennas, and a remove receiver with two more antennas which increases range and lessens the chance of having a blind spot on larger airframes. They also are more redundant since they operate on two RF frequencies as if you had two receivers running the aircraft. Should one have interference, you have one to fall back to. |
08-19-2008, 04:34 PM | #16 |
RCC Addict Join Date: Jun 2008 Location: Fresno
havent even uncoiled the antenna its not like im having my rig go more that 20 ft away from where im standing |
08-20-2008, 02:06 PM | #17 |
Pebble Pounder Join Date: Jun 2008 Location: Owasso, OK
I had it runing through some extra holes in my chassis like below, but I went with a cleaner look by cutting an atenna tube to fit and zip-tied it to the chassis. Don't have pics of the new setup right now. |
08-20-2008, 04:53 PM | #18 |
Rock Crawler Join Date: Apr 2004 Location: here
i run mine in fuel tube & ziptie it yo my tuber
