08-11-2008, 05:50 PM | #1 |
Newbie Join Date: Jul 2008 Location: toledo
| hitec
i just bought a hs 7955servo and i lost the directions and i cant get it to work right please help with a link or something
08-11-2008, 06:08 PM | #2 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Here is there website but what are you having problems with....maybe we can help. http://www.hitecrcd.com/ |
08-11-2008, 06:20 PM | #3 |
yea i went there and didnt find jack basicly i f'ed up somewhere all i does is sit there and crackle or almost sounds like its trying to turn and only move a little bit to one side what the hell did i do?
08-11-2008, 06:22 PM | #4 |
Well, are you sure it is plugged in right? Are you running a BEC? Have you tried it in any other channel?
08-11-2008, 06:36 PM | #5 |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
Did you accidently set your EPA so that it cannot move?
08-11-2008, 06:42 PM | #6 |
thats the thing i dont know how to change any of that stuff i lost the set up card or if its in the right spot
08-11-2008, 06:48 PM | #7 |
EPA is a RADIO setting and not a Servo Setting.
08-11-2008, 07:32 PM | #8 |
ok i tried screwing with that but it still only moves a bit
08-11-2008, 07:44 PM | #9 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
You're not giving us a whole lot to go on here guy. How about what radio, esc, battery etc. Are you using a bec? There is nothing to do to the servo to make it work. It either works or not. Do you have epa adjustments on your radio? As far as sound, that is normal. That is the servo constantly centering itself. The 7955TG is not as loud as the 5955TG it replaced. This servo is also a 90 degree servo, not 120 or 180 like some. |
08-11-2008, 07:50 PM | #10 |
ok here go's im running a goat system with spektrum dx3.o with a sr3000 receiver i have the servo mounted in the stock position on my axial kit no bec except the one in the goat 7.4 volt stick pack just to get it moving
08-11-2008, 07:54 PM | #11 |
Thats a little better. What are you steering EPA's set at? Are you running a BEC? Is everything else working?
08-11-2008, 08:00 PM | #12 |
the whole truck moves forward and backwards i got that far no bec so far eveything on the transmiter is at 0 ive moved it up and down did seem to make that big of a diffrence
08-11-2008, 08:06 PM | #13 |
Go to the EPA's on the radio. Then go to the steering. Hold the steering to the left, then run the EPA all the way up to 100. Then turn the steering to the right and do the same. Let us know if that helps.
08-11-2008, 08:06 PM | #14 | |
RCC Addict Join Date: Nov 2005 Location: Saving for Nationals!!
Trims should be at or near zero. Make sure the steering servo is plugged into Channel 1 and the wires are in the correct order, i.e. don't plug the servo in backwards. Then let us know. | |
08-11-2008, 08:21 PM | #15 |
hell yea guys u fixed it ty very muck i cant wait to post some pic so u can see what you guys helped me to do ty again
08-11-2008, 08:22 PM | #16 |
08-11-2008, 08:55 PM | #17 |
| No Problem |
