08-11-2008, 09:19 PM | #1 |
RCC Addict Join Date: Jan 2008 Location: www.rccrawler.com
| Default Sidewinder Settings ?
I don't have the Castle link (now I wish I got it)... What settings does the Sidwinder come programmed with ,out of the box? I know its set for brushless but is it set; for max speed/forward only or a good reversible setting that covers overall driving needs?? Thanks!!!! |
08-11-2008, 10:21 PM | #2 |
Newbie Join Date: Feb 2008 Location: Athens
From the manual: Default settings are marked with (D)* 1 : Brake/Reverse Type Option 1 : Reverse Lockout (D)* Option 2 : Forward/Brake Only Option 3 : Forward/Brake/Reverse 2 : Brake Amount Option 1 : 25% Option 2 : 50% (D)* Option 3 : 75% Option 4 : 100% 3 : Reverse Amount Option 1 : 25% Option 2 : 50% (D)* Option 3 : 75% Option 4 : 100% 4 : Punch Control Option 1 : High Option 2 : Medium Option 3 : Low Option 4 : Lowest Option 5 : Disabled (D)* 5 : Drag Brake Option 1 : Disabled (D)* Option 2 : 10% Option 3 : 20% Option 4 : 30% Option 5 : 40% 6 : Throttle Dead Band Setting 1 : Large - 0.1500 ms Setting 2 : Normal - 0.1000 ms (D)* Setting 3 : Small - 0.0750 ms Setting 4 : Very Small - 0.0500 ms Setting 5 : Smallest - 0.0250 ms CASTLE CAR ESC PROGRAMMING REFERENCE 7 : Voltage Cutoff *Denotes Default SettingOption 1 : None (D)* Option 2 : Auto-Lipo Option 3 : 5 Option 4 : 6 Option 5 : 9 Option 6 : 12 8 : Motor Timi ng Option 1 : Lowest Option 2 : Normal (D)* Option 3 : Highest 9 : Motor Type Option 1 : Brushless (D)* Option 2 : Brushed Reversing Option 3 : Brushed High Power |
08-12-2008, 08:22 AM | #3 | |
I am running two Sidewinders and two 4400kv motors on two 3s Lipos ,I wonder if the default settings will do OK? | |
08-12-2008, 08:30 AM | #4 |
| Brake/Reverse Type Option 1 : Reverse Lockout (D)* 4 : Punch Control Option 5 : Disabled (D)* 6 : Throttle Dead Band Setting 2 : Normal - 0.1000 ms (D)* What do these mean? |
08-12-2008, 09:45 AM | #5 | |
Setting 1: Reverse Lockout (Default) This setting allows the use of reverse only after the ESC senses two seconds of neutral throttle. Use it for race practice sessions and bashing, but check with your race director to see if this setting is allowed for actual racing. 4. Punch/Traction Control This setting controls how fast the throttle position within the ESC can be changed over time. This smooths high power starts and limits punch somewhat. As explained previously, acceleration is a matter of battery capability, but you may not want 100% of what the battery can deliver in every situation. Setting 5: Disabled (Default) Acceleration is only limited by battery ability. 6. Dead Band You may adjust the neutral throttle "width" of the controller with this setting. Smaller values make the controller enter forward or brake/reverse with a smaller movement of your throttle trigger for finer control. Be careful, some transmitters offer better resolution than others, if your ESC will not respond to "Neutral" throttle, make this setting larger. Setting 2: Normal - 0.1000 ms (Default) | |
08-12-2008, 09:47 AM | #6 |
| It will work, but just get the Castle link and you can make it work better withour having to manually program it...it's money well spent
08-13-2008, 07:03 AM | #7 | |
Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
Biggest thing I like about having the link is being able to play with the throttle curve. I have mine set a certain way on 3 different Sidewinders now, and they all feel perfect to me. I switched one back to the default curve and couldn't hardly drive the thing. | |
08-14-2008, 12:44 PM | #8 |
Overall i gotta find what will give best performance results for the racing Clod...but yep I should have bought the C.Link for sure, will do on my next purchase from the US ! Thanks fuctup for postin all that info!!! |
