08-14-2008, 04:42 AM | #1 |
RCC Addict Join Date: Feb 2008 Location: Nevada
| Big Probelm
I have a big problem, comp this Saturday and no rig? I started getting alot of glitching...I thought it was because of the new shocks (metal to metal) and new wheels (metal to metal) I tryed to solder caps on my motor to help with glitching (one 10 capacitor soldered tab to tab on top and two 10's twisted together and soldered tab to tab) I tryed that turned the radio on then the truck on....It took off WOT across the desk nocking eveything off the desk in its path, then it went into reverse WOT, I finally stopped it. I then took the pigtail (two 10 caps) and soldered them to the can. I tryed it again same thing again WOT??? could I have messed up the motor or ESC??? motor: 55s turn Team Integy V10 crawler ESC: Novak Rooster 12T Receiver: Airtronics MX3 w/rear stear switch Batt: 7cell 1500 mah saddle pack Can I hook up an old E-Maxx motor to it and try to see if its the motor just to illiminate it's not the motor? btw I tryed to do the one-step push button on the ESC, as soon as I let go of the button (when it turns red) pull the trigger wot and no green light? All the wires are hooked up wright and antenna looks good? plus to make it worse, I cut all the caps off just to see about using it at the comp for now....same thing WOT I now have plastic to separate all the metal to metal parts....little late for that now, should have done that first I will not be able to check back on this until 7pm when I get off work. I hope I added enough info, kinda early Last edited by prusik333; 08-14-2008 at 04:46 AM. |
08-14-2008, 11:08 AM | #2 |
Rock Crawler Join Date: Sep 2007 Location: 42N 88.02W
Sounds like ESC problem.
08-14-2008, 12:05 PM | #3 |
Rock Stacker Join Date: Feb 2007 Location: Aussie Crawlin Sin City
Changing shocks and rims shouldnt have caused any inteferance Putting the extra caps on was a good move Heres a checklist if your radio has crystals check them and or try another set Check your receiver wire, is it broken? have any exposed wire that may short out on the chassis etc, Check the plugs from the esc to reciever, sometimes they get damaged when removing them from the receiver has the radio got model memory? if so you may have selected the wrong model your throttle neutral point may have moved on your radio try re setting the speedie , remove the pinion so it doesnt take off again are your transmitter batteries charged? I know there basic suggestions but its often the simple things that go wrong good luck |
08-14-2008, 02:08 PM | #4 |
Thanks Ced RC and bunyip My boss let me check the forum real quick I forgot about checking the model memory and Rhett reminded me to unplug the motor, I forgot you can still check it without the motor being plugged in to the ESC Trying to do all this, while working, with little sleep, and comp Sat. Thanks guys |
08-15-2008, 04:26 AM | #5 |
| it crawls again
Well I got home checked the antenna wire ok, batt. voltage good, model memory good, and then took all the wires off and replugged it all back in. Works great now Not sure what the problem was....hopefully it dosen't rear its ugly head again Thanks for the checklist bunyip, I'll have to copy that and tape it to my desk for a good check Last edited by prusik333; 08-15-2008 at 04:29 AM. |
08-15-2008, 05:25 AM | #6 |
Pebble Pounder Join Date: Oct 2007 Location: Belgium
Out of curiosity, was it long ago that you installed the VF DIG? Did you switch the wires on the motor? I have almost the exact same setup (rooster crawler, integy 55t lathe, dx3/with toggle switch) and got the glitches too. My glitching started after I installed the dig and they came from the motor. I tried with a silver can 540 and no glitching. With the integy plugged in it was enough to bring the running motor close to the rx and the servo wires and it started glitching, move it away and it stopped. I changed the caps on the motor and it helped but there is still some glitching, mainly on WOT. Could the change in turning direction mess up the motor or the caps? |
08-15-2008, 03:53 PM | #7 |
Glad you got it worked out..from the sounds of it you may have had the esc's plugged in backwards into the receiver hence no signal to set the esc Trainer switching direction of the motor shouldnt cause the glitching, the only case that you may have hurt the capicators is if you used polarised caps and as soon as you send the reverse current through those they pop and release the brown smoke, they are bigger and used on some of the racing / forward only esc's just a thought on your setup have you installed a BEC ?, these will keep a preset voltage to the servos, The power for the servos bypasses the esc and goes through the external BEC if you use 2 servos and go up in volts / cell count It helps and is becoming standard equipment on crawlers I only ask cause you said it started after you installed the dig Holmes hobbies a vendor here has the castle BEC's there around 22 bucks |
08-15-2008, 09:01 PM | #8 | |
I have had the VF dig in since 4-9-08, I just recently aquired the glithching, about three weeks ago. Yes, I did switch the wires on the motor. After my comp this weekend, I'll look into my glitching further bunyip yes, I too, think it was the wire in backwards, it's the only thing that makes since. I think I was tired, groogy and a little panicked about the problem too close to the comp Last edited by prusik333; 08-15-2008 at 09:06 PM. | |
08-16-2008, 01:11 AM | #9 |
prusik333 Good luck for your comp this weekend, glad I could help |
