08-16-2008, 04:10 PM | #1 |
Quarry Creeper Join Date: Nov 2007 Location: Northern
| what's wrong?
radio: Spektrum DX6 receiver: Spektrum AR6000 ESC: CC Sidewinder Bat: CKRC 8 cell 1500 split packs Steering servo: Hitec 645 Dig servo: hitec 225mg motor: integy 55t So, I changed the esc to brushed settings with the castle link and software. I programmed the esc to learn the transmitters endpoints. Everything works pretty good for about 15-30 seconds when the dig servo engages, throttle goes wide open, no control over the car and the esc is blinking red. Any ideas? thanks |
08-16-2008, 04:33 PM | #2 |
Quarry Creeper Join Date: Apr 2007 Location: YAKIMA
are you running a cc bec with that setup
08-16-2008, 04:54 PM | #3 |
Rock Crawler Join Date: Apr 2006 Location: Eau Claire
I was having the same problem with the sidewinder in my scaler. I was told straight from CC to be sure to use a BEC with any crawler or multi servo set up, it is well worth the $20 for one.
08-16-2008, 04:56 PM | #4 |
Sounds like you BEC is weak and the Spektrum is shutting down.
08-16-2008, 05:00 PM | #5 |
what does a BEC do?
08-16-2008, 05:23 PM | #6 |
a bec stands for battery elimnating circuit. What is a BEC receiver? explain what bec is for on speedos here is a couple of links |
